svp
pigpio error : 'I2C write failed' in MAX11617
Sat Dec 08, 2018 10:16 am
Hi there,
I interfaced MAX11617 which is ADC, with RPi 3B+ using i2c protocol. I have written a code to 2 byte data reading from the slave.
while using smbus library it was giving "Error 121: Remote IO error". Then i try to use use pigpio library. Now I am getting the error pigpio.error 'i2c write failed'. How to solve it? Any suggestion, tutorial or video are most welcome.
Thank you in advance.
import pigpio
from time import sleep
bus = 1 		#i2c bus number 0 or 1 in RPi
addr_w = 0x6A 		#i2c slave address to write
addr_r = 0x6B		#i2c slave address to read
data_size = 2 		#number of bytes to read
adc = pigpio.pi() 			#init pigpio
handle_adc = adc.i2c_open(bus,add_w,0) 	#get i2c handle
print "Handle : ",handle 	#print i2c handle
adc.i2c_write_byte_data(handle_adc,0xA2,0)	#setup byte
adc.i2c_write_byte_data(handle_adc,0x61,0)	#configuration byte
try:
	While True:
		#read <data_size> bytes from i2c <handle> and store:
		#count = number of returned bytes & data = array of byte
		count, data = adc.i2c_read_device(handle_adc, data_size)
		print "Received Bytes : ",count
		#print single bytes
		for i in range(count):
			print "Byte{0} : {1}".format(i+1, data[i])
		sleep(1)
except:
	print "\nERROR"
	adc.i2c_close(handle_adc) 	#close i2c device association with handle
	adc.stop() 			#stop connection with raspberry GPIO
DirkS
Re: pigpio error : 'I2C write failed' in MAX11617
Sat Dec 08, 2018 10:18 am
Have you checked with i2cdetect that the device is properly connected and detected on the Pi?
svp
Sat Dec 08, 2018 11:14 am
Yes, I have checked with i2cdetect -y 1. The snapshot is attached. It may be due to i2c isolator ic ADUM1250 between MAX11617 and RPi!.
Return to “Python”
