epkeati
TKinter loop
Wed Dec 05, 2018 6:28 pm
Hi guys,
I just started out using raspberry Pi, and would like some help.
Problem:
I am trying to run tkinter along side code that will make cooling units turn on. I am trying to use a scale to set the temperature and turn on the units until the temperature reached the preset temp.
I been able to run the window using tkinter.
But i have not been able to update the values to turn on the cooling units.
Code:
import board
import busio
import adafruit_si7021
import time
import RPi.GPIO as gpio
from tkinter import *
import RPi.GPIO as GPIO
import time
import sys
from hx711 import HX711
import threading
import queue
# Force Python 3 ###########################################################
if sys.version_info[0] != 3:
    raise Exception("Python 3 is required.")
def usertemp(usertemp):
    ftemp=int(usertemp)
    usertempf=(int(ftemp-32)*5/9)
    print(usertempf)
    #print(temp)
    return usertempf
def turnon():
 gpio.output(17, True)
 gpio.output(22, True)
 gpio.output(4, True)
 gpio.output(27, True)
#Turn off TEC
def turnoff():
 gpio.output(17, False)
 gpio.output(22, False)
 gpio.output(4, False)
 gpio.output(27, False)
#Set up
i2c = busio.I2C(board.SCL, board.SDA);
sensor = adafruit_si7021.SI7021(i2c);
hx = HX711(5, 6)
gpio.setmode(gpio.BCM)
gpio.setup(23, gpio.IN, pull_up_down=GPIO.PUD_UP)
gpio.setup(17, gpio.OUT)
gpio.setup(22, gpio.OUT)
gpio.setup(4, gpio.OUT)
gpio.setup(27, gpio.OUT)
#Function Call
    #GUI
root = Tk()
while True:
    boxxle = Label(root, text="Boxxle Wine Chiller", font="times 35", fg="red")
    whiter = Label(root)
    tslide = Label(root, text="Set Temperature", font="times 12", fg="black")
    temperature = Label(root, text="Current Temperature\n73 Degrees F", font="times 12", fg="black")
    left = Label(root, text="Percent Left is XX%", font="times 12", fg="black")
    #slide
    slide1=Scale(root, from_=72, to=35, command=usertemp)
    usertempf = slide1
    boxxle.grid(row=0, sticky=W)
    tslide.grid(row=2, column=9)
    boxxle.grid(row=0, column=1)
    whiter.grid(row=1, column=8)
    temperature.grid(row=2, column=0)
    slide1.grid(row=2, column=8)
    left.grid(row=7, column=1)
    if sensor.temperature+3 > usertempf or sensor.temperature--3 > usertempf:
        turnon()
        print(sensor.temperature)
    else:
        turnoff()
root.mainloop()
scotty101
Re: TKinter loop
Wed Dec 05, 2018 10:00 pm
Tkinter and "while True" loops should never mix.
If you want something to happen periodically with tkinter you should use the .after method to schedule a function to be called after a period of time.
For example
root.after(100, updateGUI)
Will call a function called updateGUI after 100milliseconds.
Basic concept is that you create your GUI, schedule a function with after and then call the mainloop method.
epkeati
Re: TKinter loop
Wed Dec 05, 2018 10:22 pm
Okay cool,
But how do i make it call the function over and over again? When I tried this it only called the function once.
scotty101
Re: TKinter loop
Wed Dec 05, 2018 11:32 pm
Put a .after call inside the function that you want to be called periodically.
Then it will call itself
epkeati
Re: TKinter loop
Thu Dec 06, 2018 2:03 am
So the code would look like this?
def function()
	if on
		Do something
	self.after(100, function)
root = tk
root.after(100,function)
scotty101
Re: TKinter loop
Thu Dec 06, 2018 9:35 am
def function()
	if on
		Do something
root = tk
Yeah pretty much. Just don't forget you still need the root.mainloop()
Return to “Python”
