bluePiuser
auto start RPI 3B/3B+ python 3.6 and opencv 3 code
Sat Dec 01, 2018 9:37 pm
After searching and condensing, I figured out how to autostart on reboot python and opencv programs on raspberry pi raspbian stretch. Although it autostarts, if the programs stops, it won't start without a reboot. I didn't succeed yet in doing this as a service. This works with full stretch install.
Create as pi user an sh file:
/home/pi/run_program.sh
Change permissions:
chmod 755 run_program.sh
Edit run_program.sh with something like:
export DISPLAY=:0.0
cd /home/pi/stuff
py opencv_program.py
Then update autostart file.
cd /home/pi/.config/lxsession/LXDE-pi
Add this line to the autostart file already there:
@/home/pi/run_program.sh
This works well. If the power goes out, and my RPIs restart, the programs are running. I can connect to desktop directly or with VNC and see the cv2.imshow windows running.
PhatFil
Re: auto start RPI 3B/3B+ python 3.6 and opencv 3 code
Sat Dec 01, 2018 11:24 pm
look at systemd https://www.raspberrypi.org/documentati ... systemd.md
It will let you define your programs as services with the capacity to stop and start check status etc.
bluePiuser
Fri Dec 07, 2018 8:42 pm
Hi PhatPhil, I created several services that work with python. However, I could not create one python and opencv as the service failed to start. The service could not find a window display at boot time.
Return to “Python”
