Robotix92
Quadrature encoder serial pins question
Tue Sep 11, 2018 4:13 pm
I hate to just have made an account to ask a question, and i'm also not sure if this is the right section, but ... I've been following some guides online on setting up my pi and getting an lcd to work (all went well). Now i have a quadrature encoder, specifically a US Digital EM1-1000-N encoder (link below), which i want to get a reading telling me revolutions. I've been following a guide (link below), but it doesnt tell me how to wire it up. Any suggestions or ideas? Would really appreciate the help, Thanks!
https://www.usdigital.com/products/em1
https://walchko.github.io/blog/Robots/R ... oders.html
MrYsLab
Re: Quadrature encoder serial pins question
Tue Sep 11, 2018 5:47 pm
Since the output voltage specs show a range of 0.05 to 4.8 volts you can attach it directly to GPIO pins of your choice.
Here is a link to a simple Python program that should get you started:
http://abyz.me.uk/rpi/pigpio/examples.h ... encoder_py
joan
Tue Sep 11, 2018 5:59 pm
It has contacts marked A B I - + (not in that order).
Connect A and B to separate GPIO. Connect - to a Pi ground (say pin 6) and + to 5V (say pin 2). You may leave I unconnected. Configure the software you are using by specifying the GPIO connected to A and B.
https://pinout.xyz/
danjperron
Tue Sep 11, 2018 6:07 pm
No you can't!
You need to use resistors divider or mosfet converter to step down output to 3.3V.
Check Sparkfun or adafruit i2c 5V to 3.3V adapter
https://www.adafruit.com/product/757
Robotix92
Tue Sep 11, 2018 6:10 pm
As far as i understand the encoder, it needs the pin needs to interrupt in order to accurately read the encoder signal (maybe?). Can i follow the code shown in the link and just define pins A, B?
And i guess i'll use some resistors to step down the voltages? I'll do a little more research on this, thanks for the replies! Any advice helps.
import time
from serial import Serial
count = 0
COUNTS_TO_METERS = 0.001  # this depends on the encoder system
def main_loop():
  ser = Serial('/dev/tty.usbserial0', 115200)
  while True:
    time.sleep(1)  # time depends on speed of robot
    position += count * COUNTS_TO_METERS
    count = 0
    # a super simple serial response to report position
    if ser.read() == 'p':
      ser.write(position)
# an interrupt that gets called every time A or B changes
# you can do this with RPi.GPIO on the raspberry pi
def interrupt_AB():
  A, B = readEncoderPins()
  if A ^ B == 1:
    count += 1
  else:
    count -= 1
MrYsLab
Tue Sep 11, 2018 6:17 pm
@danjperron is correct. Sorry, I have been playing with Arduinos recently and my brain was stuck on 5v GPIO. Here is a link to building a voltage divider: https://elinux.org/RPi_GPIO_Interface_Circuits
Robotix92
Tue Sep 11, 2018 6:21 pm
Thank you! I actually got this same encoder working on the arduino. I'm not too familiar with the pi but i'm experimenting with it today. I want to eventually make it work with an LCD and a few other sensors
joan
Tue Sep 11, 2018 6:35 pm
You can use a pair of resistors of the same value as a resistor divider. You need one pair for A and another pair for B. That will drop the output voltage from 5V to a Pi safe 2.5V (still high enough to be seen as logic high at the Pi).
joan
Tue Sep 11, 2018 6:37 pm
I don't understand how the code you linked is relevant to the encoder. Have you got a circuit diagram to show the intended usage?
OutoftheBOTS
Tue Sep 11, 2018 7:31 pm
The code that was linked isn't complete and is just Python Pseudo Code not complete python code.
Reading quadrature encoders in python on RPi isn't very efficient to do because the fact that python on RPi isn't real time and has a lot of latency. The very easiest way to do it is with an external quadrature counter.
Here is a good video explaining the working of the encoder and best way of writing python code to count it see https://www.youtube.com/watch?v=p4BCFhIuC88&t=461s
And here is a video showing the advantage of using an external counter to do it. see https://www.youtube.com/watch?v=41ogu0UlwCc&t=12s
moderatelyfunky
Tue Sep 11, 2018 7:58 pm
I'm considering replacing the steppers in my project with dc and I wasn't sure where to start, but now I know.
Thanks Outofhebots, I really appreciate both of these videos!
Robotix92
Tue Sep 11, 2018 8:28 pm
Exactly what i needed !! I used a voltage divider with resistors are discussed above and it seems to work. My numbers are off though but i'll dig into this some more. My encoder has 1000 counts per rev but im getting like 3500 per rev! Maybe i can just add a divider in my code to compensate? Thanks a ton for the vids
Return to “Python”
