BramWerbrouck
PyImageSearch - Green Ball Tutorial
Mon Aug 06, 2018 9:00 am
I followed the instructions from PyImageSearch.com to install OpenCV and want to try the "green ball" tutorial.
but I have an error:
[INFO]: waiting for the camera to warmup...
 File "pi_alarm.py", line 28, in <module>
   vs = VideoStream(usePiCamera=args["picamera"] > 0).start()
 File "/home/pi/.virtualenvs/cv/lib/python3.5/site-packages/imutils/video/videostream.py", line 13, in __init__
   from .pivideostream import PiVideoStream
 File "/home/pi/.virtualenvs/cv/lib/python3.5/site-packages/imutils/video/pivideostream.py", line 2, in <module>
   from bicamera.array import PiRGBArray
ImportError: No module names 'picamera'
this is the code:
# import the necessary packages
from __future__ import print_function
from imutils.video import VideoStream
import argparse
import imutils
import time
import cv2
import RPi.GPIO as GPIO
# initialize GPIO
redLed = 21
GPIO.setmode(GPIO.BCM)
GPIO.setwarnings(False)
GPIO.setup(redLed, GPIO.OUT)
# construct the argument parse and parse the arguments
ap = argparse.ArgumentParser()
ap.add_argument("-p", "--picamera", type=int, default=-1,help="whether or not the Raspberry Pi camera should be used")
args = vars(ap.parse_args())
# initialize the video stream and allow the camera sensor to warmup
print("[INFO] waiting for camera to warmup...")
time.sleep(2.0)
# define the lower and upper boundaries of the "green"
# ball in the HSV color space
greenLower = (29, 86, 6)
greenUpper = (64, 255, 255)
# Start with LED off
GPIO.output(redLed, GPIO.LOW)
ledOn = False
# loop over the frames from the video stream
while True:
	# grab the next frame from the video stream, Invert 180o, resize the
	# frame, and convert it to the HSV color space
	frame = vs.read()
	frame = imutils.resize(frame, width=500)
	frame = imutils.rotate(frame, angle=180)
	hsv = cv2.cvtColor(frame, cv2.COLOR_BGR2HSV)
	# construct a mask for the color "green", then perform
	# a series of dilations and erosions to remove any small
	# blobs left in the mask
	mask = cv2.inRange(hsv, greenLower, greenUpper)
	mask = cv2.erode(mask, None, iterations=2)
	mask = cv2.dilate(mask, None, iterations=2)
	# find contours in the mask and initialize the current
	# (x, y) center of the ball
	cnts = cv2.findContours(mask.copy(), cv2.RETR_EXTERNAL,
		cv2.CHAIN_APPROX_SIMPLE)
	cnts = cnts[0] if imutils.is_cv2() else cnts[1]
	center = None
	# only proceed if at least one contour was found
	if len(cnts) > 0:
		# find the largest contour in the mask, then use
		# it to compute the minimum enclosing circle and
		# centroid
		c = max(cnts, key=cv2.contourArea)
		((x, y), radius) = cv2.minEnclosingCircle(c)
		M = cv2.moments(c)
		center = (int(M["m10"] / M["m00"]), int(M["m01"] / M["m00"]))
		# only proceed if the radius meets a minimum size
		if radius > 10:
			# draw the circle and centroid on the frame,
			# then update the list of tracked points
			cv2.circle(frame, (int(x), int(y)), int(radius),
				(0, 255, 255), 2)
			cv2.circle(frame, center, 5, (0, 0, 255), -1)
			# if the led is not already on, turn the LED on
			if not ledOn:
				GPIO.output(redLed, GPIO.HIGH)
				ledOn = True
	# if the ball is not detected, turn the LED off
	elif ledOn:
		ledOn = False
	# show the frame to our screen
	cv2.imshow("Frame", frame)
	key = cv2.waitKey(1) & 0xFF
	# if the 'q' key is pressed, stop the loop
	if key == ord("q"):
		break
# do a bit of cleanup
GPIO.cleanup()
cv2.destroyAllWindows()
vs.stop()
What did I do wrong? Can anyone help me?
B.Goode
Re: PyImageSearch - Green Ball Tutorial
Mon Aug 06, 2018 9:25 am
Can anyone help me?
It might help if you specify what Operating System is running on your RPi.
It seems you are running this script in a python virtual environment (venv)
Is the standard picamera module accessible from that environment?
To check, within that venv, just start the Python3 interpreter and try
from picamera import PiCamera
(I am also a little puzzled by the reference to 'bicamera', but I am not familiar with the tutorial or library you are using so this might be completely normal... )
texy
Mon Aug 06, 2018 10:55 am
Can anyone help me?
I think you mean 'picamera' - https://www.raspberrypi.org/documentati ... /README.md
Texy
B.Goode
Mon Aug 06, 2018 6:05 pm
The attribution is unclear. But no, that's not what I meant. I was querying this extract from the traceback -
That seems to be from inside an installed module?
Return to “Python”
