magdalinka
Running a never ending loop Python script at startup
Tue Jun 26, 2018 8:25 am
I have a problem with running the python code! It runs on startup, and then stops. The python code contains "while loop" so It should never stop. When I write it in console manualy then it is working in the background but if I write it in rc.local It works only on the start up.
Here is my rc.local code: "sudo python /home/pi/my_directory/code_name.py & "
How to make it run in background automaticly?
DirkS
Re: Running a never ending loop Python script at startup
Tue Jun 26, 2018 8:54 am
You will have a much better chance of a helpful response if you start a new topic instead of reviving a 5 year old one...
Tue Jun 26, 2018 8:56 am
magdalinka,
A nice easy way to do this is to use the systemd. systemd is the initialization system of Raspbian.
See my post here: viewtopic.php?t=138861#p921354
See this little thread where someone gets Python running at startup using systemd: viewtopic.php?t=216371
You will find examples, blogs and tutorials about using systemd all over the net.
texy
Tue Jun 26, 2018 10:13 am
Split from original instead.
Texy
Return to “Python”
