what does this code do...?
Posted: Thu Jun 14, 2018 1:15 pm
by Rascalpi
Hi
From the URL:
http://www.cl.cam.ac.uk/~db434/raspi/blob_detection/
there is the following line of code:
red, green, blue = image[x, y]
also further down:
image[x, y] = 0, 0, 0
I'm new to Python (used to C) so the simultaneous assignment concept is new.
I presume the individual RGB values are being passed to/from the array - but how exactly?
regards
Russell
Re: what does this code do...?
Posted: Thu Jun 14, 2018 1:27 pm
by scotty101
Python can return complex types, in this case it returns a tuple.
this_is_a_tuple = (1, 2, 3, 4)
You can get the different parts to this in two different ways, long handed way
part1 = this_is_a_tuple[0]
part2 = this_is_a_tuple[1]
part3 = this_is_a_tuple[2]
part4 = this_is_a_tuple[3]
or unpack them all at once
part1, part2, part3, part4 = this_is_a_tuple
You can even decide that you don't want all of them and use the underscore symbol to ignore 1 or many parts. This will get parts1, 2 and 4 but ignore part 3.
part1, part2, _, part4 = this_is_a_tuple
When a function returns as a tuple you can grab the entire structure
RGB = getColor(x,y)
or you can get the different parts
R, G, B = getColor(x,y)
The same in reverse works with assignments to a variable.
Does that help in explaining it?
Posted: Thu Jun 14, 2018 1:52 pm
by Rascalpi
Many thanks for the reply - most helpful
Russell
Posted: Thu Jun 14, 2018 7:44 pm
by Paeryn
Technically the underscore doesn't ignore a value, an underscore is a variable name just like part1 so it gets assigned to like all the others.
