saras.nes
Line counter
Mon Jun 04, 2018 6:20 am
I've Raspberry and SHARP 2Y0A02 distance sensor. I wish to make a counter of moved object, but I've a problem that my code is counting every time it detects object and until it's finished it counting like million times. What I need to do is to count only +1 until signal lost and wait for signal once again detected and count +1 next object. My code is:
import RPi.GPIO as GPIO
import time
GPIN = 4
GPIO.setmode(GPIO.BCM)
GPIO.setup(GPIN, GPIO.IN)
counting = 0
try:
        while True:
               if GPIO.input(GPIN) == 1 :
                        counting = counting + 1
                        print(counting)
                        time.sleep(1)
               else:
                        counting = counting
                        print (counting)
                        time.sleep(1)
except KeyboardInterrupt:
        GPIO.cleanup()
Output look like Image
As you see when signal lost everything seems ok it keeps last digit, but when signal is detected it counts endlessly +1 until signal lost. Is there a solution for making this sensor work as counter (button like style)? Thank you.
Re: Line counter
Mon Jun 04, 2018 9:29 am
Try this version
#!/usr/bin/python
import time
GPIN = 4
GPIO.setup(GPIN, GPIO.IN,pull_up_down=GPIO.PUD_DOWN)
counting = 0
try:
    while True:
        if GPIO.input(GPIN):
            print(counting)
        else:
            counting = counting
            print (counting)
        time.sleep(1)
    GPIO.cleanup()
BTW, you may want to avoid using GPIO04 as that's the default pin for 1-wire sensors.
This is a doctor free zone.
saras.nes
Re: Line counter
Mon Jun 04, 2018 10:10 am
I'm still very noob on Raspberry but I like it very much :-)
Nah it's the same when the sensor is covered it keeps counting +1. But i need that it count like only one time if sensor is covered and wait till other interruption. Now it's printing:
0 #No sensor covered
1 #Sensor covered 1st time
2 #Sensor covered 1st time
3 #Sensor covered 1st time
4 #Sensor covered 1st time
5 #Sensor covered 1st time
6 #Sensor covered 1st time
7 #Sensor covered 1st time
8 #Sensor covered 1st time
9 #Sensor covered 1st time
10 #Sensor covered 1st time
11 #Sensor covered 1st time
12 #Sensor covered 1st time
12 #No sensor covered
13 #Sensor covered 2nd time
14 #Sensor covered 2nd time
15 #Sensor covered 2nd time
And I need output like:
1 #No sensor covered
2 #Sensor covered 2nd time
I hope now is a more clear what I want to reach.
And what PIN i should use than for this project? I'm on Raspberry Pi 3 model B+
Thank you.
hippy
Re: Line counter
Mon Jun 04, 2018 10:58 am
Try this version
Not sure how that will work better as it mostly seems to be a refactoring of the original code with the two 'time.sleep()' commands taken out from inside the 'if' command and specifying a pull-down.
The problem appears to be that it keeps counting while in contact. You need to create some sort of flag which can determine if it's a new touch or a continuation of the last touch for example, in pseudo code -
count = 0
alreadyCounted = False
While True
  If contact() and ( not alreadyCounted )
    count = count + 1
    alreadyCounted = True
  Else
PiGraham
Re: Line counter
Mon Jun 04, 2018 11:06 am
You need to count one when the input changes from low to high. You are counting whenever the input is high.
You can keep a flag to detect the change or use one of many edge detection functions.
    while True:
                   GPIO.wait_for_edge(GPIN, GPIO.RISING)
                   print (counting)
saras.nes
Re: Line counter
Mon Jun 04, 2018 12:10 pm
hippy your solutions seems to work thank you, just the problem now when i change ranges of object it also counting +1 so next question is how we can eliminate counting from range of object? It's getting different V in range so that's why it counts. So i just need like signal 1 no signal 0 and count these between signals. Maybe then i can describe somehow in V in range?
PiGraham
Re: Line counter
Mon Jun 04, 2018 1:20 pm
Use a comparator to detect if the sensor output voltage is above or below an adjustable threshold.
If you just connect the output to a gpio pin the gpio has a fixed threshold.
You will have to choose a working distance. Near that limit you will get some multiple triggers. Try to arrange for your objects to pass across the view of the sensor rather than coming toward t head on so you can avoid the transition range that can cause extra counts.
You can also use some "debounce timeouts to that you don't count until the sensor has been steady in one state or the other for some minimum time.
Why is this the a "line counter" and what distance are you measuring with the sharp sensor?
PingoBags
Re: Line counter
Mon Jun 04, 2018 1:38 pm
A simple way would be to store the pin state. The just increase the counter by one when the state changes.
Using GPIO 13
import time
GPIN = 13
Pinstate = False
counting = 0
try:
  while True:
    if GPIO.input(GPIN) and not Pinstate:
      counting += 1
      Pinstate = True
    elif not GPIO.input(GPIN) and Pinstate:
        Pinstate = False
    time.sleep(1)
    print (('Sensor covered (%s)' if Pinstate else 'No sensor covered (%s)') % counting)
        GPIO.cleanup()
saras.nes
Re: Line counter
Mon Jun 04, 2018 1:40 pm
I'm not measuring distance with that, I wan't it to use as counter of items comes trough line. I.e. i want to count how many watermelons was passed trough the line in some give time. I just ordered this in thoughts that i can convert it as counter not a distance meter. But it start looking i'm not that skilled yes to make it count, but with your help i'll get to another level :-)
gordon77
Re: Line counter
Mon Jun 04, 2018 1:42 pm
How do you have it wired ? It appears it has an analogue output(0.4 to 2.8v) dependent on distance, if you have it directly connected to a GPIO input then the input is just seeing a 0 or a 1 when it exceeds the threshold.
If you want to measure range you will need a ADC.
https://www.sparkfun.com/products/8958
PiGraham
Re: Line counter
Mon Jun 04, 2018 1:55 pm
You could use a through beam or retroreflecting optical sensor for a more positive detection.
https://uk.rs-online.com/web/c/automati ... c-sensors/
https://www.ebay.co.uk/itm/Sick-WL12-2P ... SwFq1bEok3
Industrial sensors will probably perform better but you may need to level shift the output to suit the Pi 3.3V inputs.
hippy
Re: Line counter
Mon Jun 04, 2018 3:50 pm
Not quite sure how you mean. You sensor seems to be an analogue device indicating how far away an object is. If you have an ADC you can read that, determine when an object is present at some particular distance, and have some other level which can be used to indicate when it no longer is. Only count when an object comes into range. Something like ...
While True
  While readSensor() < 20
    Do Nothing
  count = count + 1
  While readSensor() > 10
    Do Nothing
pcmanbob
Re: Line counter
Mon Jun 04, 2018 4:14 pm
Try this code, it waits for a change from gpio = 0 and then from gpio =1
so it only adds to the count on change of gpio state.
it should sill work even if you are using an analogue sensor as a digital input because when the range is such that the output voltage exceeds the low threshold and becomes a high, it will not change again until the voltage drops sufficiently that it falls below the high threshold and so becomes a low once again. ( I think that makes sense I know it work,s just putting it in to words is the hard bit to make it understandable. )
import time
GPIN = 4
counting = 0
try:
        # this is the main loop
        while True:
               	# now we wait in a new loop for gpio to equal 1
                while GPIO.input(GPIN) == 0:
                    time.sleep(0.5)
                # add 1 to your count  and print
                print(counting)
                # now we wait in yet another loop to the gpio to equal 0
                while GPIO.input(GPIN) == 1:
                    time.sleep(0.5)
                # then we return to the start of the main loop
        GPIO.cleanup()
untested code expect error.
PiGraham
Re: Line counter
Mon Jun 04, 2018 4:16 pm
The sharp sensor will cross the gpio input voltage threshold as some fixed distance so it can operate as a digital present / not present detector. Anything closer than X will send the input high (or low). Using it direct works but allows no adjustment other than moving the sensor physically.
Reading on a curved melon could cause problems with multiple triggers as the distance changes over the curve.
pcmanbob
Re: Line counter
Mon Jun 04, 2018 4:26 pm
may be , you might be able to solve it by putting the sensor as close to the line as possible, so that the you get a high as soon as a melon comes in to range, the only way to know for sure is to do some field tests.
Return to “Python”
