ricardo.santos
open txt file and get variables inside
Thu Mar 15, 2018 9:36 pm
hi. i'm newbie in python and need some help
I have a txt file like with a structure like that below
####inputs
###bla-bla-bla
xpto = 2
zzz = 10.25
name = Jonh
interval = 2
How can I do in python to open the file, and get the variables as strings that have the equal sign (=)
Re: open txt file and get variables inside
Thu Mar 15, 2018 11:38 pm
This is a doctor free zone.
ricardo.santos
Fri Mar 16, 2018 9:20 am
will this work on the pi
I don't have the lib in the python3 by default
is that not specifically for ini files in windows
thanks
Fri Mar 16, 2018 9:29 am
Python is python regardless. Things only won't work if they have a hardware dependency like a GPIO pin driver.
rurwin
Fri Mar 16, 2018 10:52 am
I assume you've checked the standard library and there's nothing there to help.
In that case I'd
pull in the file with readlines
filter out any text after the first #
remove leading whitespace
filter out blank lines
use a regular expression such as "^([^=]+)=([^=]+)$" to split each line in two.
That probably could be reduced to almost that number of lines of code by using filter and map.
gordon77
Fri Mar 16, 2018 2:42 pm
This was an interesting question and I feel I've learnt something. :D
I assumed you want to read the lines and set the read variables with the values read. Maybe l went further than you asked?
Maybe not the most efficient but works with your data in data.txt
with open("data.txt", "r") as file:
   inputx = file.readlines()
for lines in range (0,len(inputx)):
   a = (inputx[lines])
   b =  a.split("=",2)
   if len(b) == 2:
      c = str.strip(b[0])
      d = str.strip(b[1])
      e = d.replace('.','',1)
      if str.isdecimal(d):
         f = int(b[1])
      elif str.isdecimal(e):
         f = float(b[1])
      else:
         f = b[1]
      globals()[c] = f
# check variables read and set
print (xpto,zzz,name,interval)
rurwin
Sat Mar 17, 2018 12:30 am
Yeah, split is better than a regular expression.
It can be done more neatly with maps, filters and comprehensions though.
with open("variables.txt","r") as f: stuff = f.readlines()
#remove everything after first # and split at first =
stuff = map(lambda x: x[:x.find("#")].split("=",1), stuff)
#remove blank lines and lines without an =
stuff = filter(lambda x: len(x) > 1, stuff)
#strip leading and trailing whitespace
stuff = map(lambda x: [y.strip() for y in x], stuff)
#convert to dictionary
variables = {d[0]:d[1] for d in stuff}
print (variables)
print ("name is ", variables["name"])
This produces:
{'xpto': '2', 'zzz': '10.25', 'name': 'Jonh', 'nothingafterequal': '', 'interval': '2'}
name is Jonh
I also delayed doing the strip until I could get at the spaces around the = as well.
Return to “Python”
