micksulley
Connect to MariaDB from Python
Mon Jan 29, 2018 2:56 pm
Up to date Raspbian. I have installed MariaDB following this link
https://howtoraspberrypi.com/mariadb-ra ... pberry-pi/
and I am trying to connect to it from within Python following information here
https://mariadb.com/resources/blog/how- ... ms-mariadb
but it fails at the import statement
>>> import mysql.connector as mariadb
  File "<stdin>", line 1, in <module>
ImportError: No module named mysql.connector
Have I missed something here? Do I need to install something else
Jednorozec
Re: Connect to MariaDB from Python
Mon Jan 29, 2018 8:24 pm
MariaDB provides Python support through the MySQL Python package, which does not come installed with the default Python installation on most distros.
Did you install it?
The most important leg of a three legged stool is the one that's missing.
It's called thinking. Why don't you try it sometime?
micksulley
Re: Connect to MariaDB from Python - Fixed
Mon Jan 29, 2018 9:06 pm
Yes that was it, all working now.
Many Thanks
Mick
MadeMess
Fri Aug 24, 2018 3:23 pm
For anyone else that comes through here - I couldn't get it working until I lucked into the right download:
sudo apt-get libmariadbclient-dev
This enabled:
pip install mysql-connector
As per https://github.com/sanpingz/mysql-connector provided example, I was able to connect.
This was for python3.7 running in virtualenv.
rivandemo
Sat Dec 08, 2018 4:03 pm
I think "install" is missing after "sudo apt-get" in "sudo apt-get libmariadbclient-dev"
Return to “Python”
