Impresario
Initiating and controlling omxplayer using a python app
Sat Oct 28, 2017 9:38 pm
I recently assembled a Raspi 3 with the 7" touchscreen in order to play MP4 videos contained on a 128GB USB thumb-drive.
Starting omxplayer from the command line worked great and i was surprised at the quality of the display. To complete my vision, i initiated omxplayer from a python app and that's where I got stuck. There seemed to be no way to end the app, except by remoting into the raspi with SSH from another terminal, identifying omxplayer's process ID and killing it.
Of course I wanted to do more than just kill the app, I also wanted to pause/resume, fast forward and perform all the other functions that are possible through keystrokes in the command line method. I tried various ways of routing keystrokes to my python app, but nothing worked.
I'm neither a linux nor python expert. Can someone point me the right way?
Thank you
gkreidl
Re: Initiating and controlling omxplayer using a python app
Sun Oct 29, 2017 6:22 am
Thank you
Something like this:
omxprocess = subprocess.Popen(['omxplayer',uri],stdin=subprocess.PIPE)
where "uri" is a file path or URL.
You can send keyboard commands like this:
omxprocess.stdin.write('q')
Minimal Kiosk Browser (kweb)
Impresario
Sun Oct 29, 2017 10:20 pm
Thank you for your suggestion. Here is my test code:
import subprocess
import time
moviepath = 'path to my MP4 file'
omxprocess = subprocess.Popen(['omxplayer', moviepath], stdin=subprocess.PIPE)
time.sleep(30)
print('Time to quit')
The video starts but never terminates. After 30 secs, the last line throws an error: Typeerror: 'str' does not support the buffer interface
I appreciate your advice!
Douglas6
Sun Oct 29, 2017 10:48 pm
There are at least a couple of Python libraries that use D-Bus to control omxplayer. One of them I wrote; see here: https://github.com/Douglas6/omxcontrol
OutoftheBOTS
Mon Oct 30, 2017 9:11 am
Is it easier to play the video file from within Python instead of playing it with an external process, this would give you much more control.
I see that pygame has video playing fuctions
gkreidl
Mon Oct 30, 2017 9:14 am
import subprocess
import time
time.sleep(30)
use this:
omxprocess = subprocess.Popen(['omxplayer',moviepath],stdin=subprocess.PIPE,stdout=None,stderr=None,bufsize=0)
time.sleep(10)
omxprocess.stdin.write(b'q')
Impresario
Mon Oct 30, 2017 2:14 pm
Thank you all for the help. The modification to my python test code worked great. Sorry I'm not more versed in python, but I'm learning. I'm also going to test the D-Bus approach and report back.
zipzit
Wed May 23, 2018 5:58 pm
Impresario and gkreidl:
You guys rock! Many thanks... Here's my code based on your share:
import subprocess
import time
while 1:
    moviepath = 'http://192.168.1.11/fileserver/downloadVideo'
    omxprocess = subprocess.Popen(['omxplayer', moviepath, '-b'],  stdin=subprocess.PIPE, stdout=None, stderr=None, bufsize=0)
    time.sleep(10)
    time.sleep(5)
In my case, I'm running a node server within my local network, serving up video files via Express and `res.sendFile(...)` I wanted to verify when the server swapped the video, that the Pi received the latest and greatest. Note, the '-b' after moviepath is for full screen, blackout background omxplayer mode...
Again, thanks to you guys for sharing...
pgannett
Sat Jul 13, 2019 10:29 pm
Thanks to everyone who helped put this together. Helping me out on a project big time! Only issue I'm having is quitting once it starts. Typing q doesn't have any effect. Only way I can get it to quit now is pulling the ethernet cable on the camera. I'm to to raspberry pi's and python. Thoughts?
Douglas6
Sat Jul 13, 2019 11:20 pm
Ctrl-C is the standard way to halt an interactive Python program.
Return to “Python”
