GPIOZero - 2 fonction for same GPIO ?
Posted: Mon Sep 18, 2017 4:16 pm
by smalldragoon
Hello !
I'm a new user of Raspberry and I'm now playing with the GPIOZero library.
So far so good, when I try to use 4 different pin to simulate 4 arrow keys with buttons, everything works properly.
Now, I would like to use as well 2 of the pins keeping them old let's say for 1 sec .
first , I'm already blocked using only 1 button :
When I define a second check for my GPIO pin, it says that it is already use ( indeed as it is monitoring for a single push )
My final goal is : if I press the 2 button simulteanously during 1 sec, it generate "enter" as ex ( through the pyautogui library )
Is there something I'm missing here ? a trick to have both working ? Code below to be more understandable
Thx !!
from gpiozero import Button
from signal import pause
import pyautogui
def send_l():
   pyautogui.press('left')
def send_r():
   pyautogui.press('right')
def send_u():
   pyautogui.press('up')
def send_d():
   pyautogui.press('down')
def send_ok():
   pyautogui.press('enter')
bleft = Button(4)
bright = Button(17)
bup = Button(27)
bdown= Button(22)
b_ok = Button(4, hold_time=1)
bleft.when_pressed = send_l
bright.when_pressed = send_r
bup.when_pressed = send_u
bdown.when_pressed = send_d
b_ok.when_held = send_ok
pause()
Re: GPIOZero - 2 fonction for same GPIO ?
Posted: Mon Sep 18, 2017 7:50 pm
by thagrol
You can use when_pressed and when_held on the same Button object. But you will get both on a hold.
Have a look at the cmdbutton class here https://github.com/thagrol/pwdgen/blob/master/pwdgen.py for one way to detect short and long button presses.
There's code in there you won't need but it should point you in one possible direction.
Haven't needed to solve you final step so not able to help with that.
In my code referenced above, the when_pressed callback function stores the time. The when_released function calculates the elapsed time and fires the short press action or does nothing depending on how much time has elapsed. The hold action is handled by the when_held callback though you could do this within the when_released function.
Posted: Tue Sep 19, 2017 8:29 am
by LetHopeItsSnowing
You need to use the same Button object for both the pressed and held events. i.e.there is only 1 button so you only have 1 object.
import pyautogui
def send_l():
def send_r():
def send_u():
def send_d():
def send_ok():
bleft = Button(4, hold_time=1)
bright = Button(17)
bup = Button(27)
bdown= Button(22)
bleft.when_held = send_ok
pause()
When you press and hold the left button you are going to get 2 messages, 1 saying "left" and 1 saying "ok".
If you want to differentiate between a short press and a long press, you might be better using when_released rather than when_pressed. If you use when_released you can check the active_time to see how long the pressed was pressed for. If the time it was pressed for is less than the hold_time you could consider it a short press.
def released():
    print("released after {} seconds".format(but.active_time))
    if but.active_time < but.hold_time:
        print("this is a short press")
def held():
    print("button held")
    print("this is a long press")
but = Button(4, hold_time=1)
but.when_released = released
but.when_held = held
Fyi - I wrote the code blind and it hasnt been tested, but hopefully you get the idea.
Mart
Posted: Tue Sep 19, 2017 3:47 pm
by thagrol
There's an active_time property? Didn't see that in the documentation! Would simplify my code referenced above.
Posted: Wed Sep 20, 2017 7:51 am
Yes.
Its a little 'hidden' in the documentation but it is there. Its actually part of the EventsMixin which is inherited by DigitalInputDevice which is inherited by Button!
There is a clue on the held_time property of button https://gpiozero.readthedocs.io/en/stab ... .held_time.
One of the challenges is that the gpiozero docs dont show inherited methods and properties, I assume, to make them simpler to read and digest as they would be considerably bigger.
Fyi - I knew it was there as I submitted the pull request for the Button 'held' events, although I'm not sure I would recognise any of my code (it was changed a lot)!
Posted: Wed Sep 20, 2017 12:15 pm
by thagrol
Excelent. Thanks.
Posted: Mon Sep 25, 2017 3:27 pm
by smalldragoon
Hello All,
Thanks for all the answers ! I did a lot of tests before re-posting ...
I tried to do few tests and seems that I have an issue in my GPIOZERO
here is the status :
I'm using python3 ( ie: python3 {name of my script} )
I indeed run it as root
I though to a failure of my GPIO, so tried again with an old sript, it's working perfectly
I checked and my gpiozero version is 1.4.0
pigpio/stable,now 1.60-1 armhf [installed]
python-gpiozero/stable,now 1.4.0 all [installed]
python-gpiozero-doc/stable 1.4.0 all
python-pigpio/stable,now 1.60-1 all [installed]
python-rpi.gpio/stable,now 0.6.3~jessie-1 armhf [installed]
python3-gpiozero/stable,now 1.4.0 all [installed]
python3-pigpio/stable,now 1.60-1 all [installed]
python3-rpi.gpio/stable,now 0.6.3~jessie-1 armhf [installed]
raspi-gpio/stable,now 0.20170105 armhf [installed]
running this code below , as soon as I generate my input on pin 4 , I have :
def released():
def held():
File "/usr/lib/python3/dist-packages/gpiozero/pins/rpigpio.py", line 213, in _call_when_changed
super(RPiGPIOPin, self)._call_when_changed()
File "/usr/lib/python3/dist-packages/gpiozero/pins/pi.py", line 268, in _call_when_changed
method()
File "/usr/lib/python3/dist-packages/gpiozero/mixins.py", line 327, in _fire_events
self._fire_deactivated()
File "/usr/lib/python3/dist-packages/gpiozero/mixins.py", line 360, in _fire_deactivated
super(HoldMixin, self)._fire_deactivated()
File "/usr/lib/python3/dist-packages/gpiozero/mixins.py", line 306, in _fire_deactivated
self.when_deactivated()
File "forum.py", line 6, in released
TypeError: unorderable types: NoneType() < float()
What does it mean ? it is not explicitley stating an error, but I guess it shouldn't list all this ...
what am I missing ?
Thx !
Posted: Mon Sep 25, 2017 3:49 pm
by scotty101
What is the output of the following line from your code?
I'm no gpiozero expert but I think you need to do something with EventsMixin to use active_time.
Posted: Wed Sep 27, 2017 7:56 am
by smalldragoon
Hi
From my understanding, there is no output as the code is not able to calculate the time , no ?
Posted: Wed Sep 27, 2017 8:13 am
by elParaguayo
The error message is quite clear in explaining the problem.
You are trying to see if but.active_time is less than but.hold_time. The problem is that but.active_time has a value of None. You can't compare None to a numerical value hence the error (actually, I think python 2 allows this but python 3 doesn't...).
You may need to follow Scotty101's advice to get active_time working.
Posted: Fri Sep 29, 2017 2:45 pm
by smalldragoon
Hello All,
I still don't get it, sorry
searched on official document from GPIOZero :
The length of time (in seconds) that the device has been active for. When the device is inactive, this is "none"
-> my undestanding is that when the button is released, value is set back to none
So, I tried to define a variable to store the value of active_time, but still get "none" as value
I guess there is something in the basis I'm not understanding.
Help much appreciated :D
thx !
@elpapaguayo : I understand the comparison, what I don't get is why active_time is always set to none
Posted: Sat Sep 30, 2017 2:14 am
by CyberGyver
The value of active_time is always "None" for me, but this code does the job:
#!/usr/bin/env python3
import time
# Physical pin 40 = BCM pin 21. Button hold time 2 seconds.
button = Button(21, hold_time=2)
def pressed():
    global press_time
    press_time = time.time()
    print("pressed at %s" % (press_time))
def released():
    release_time = time.time()
    pressed_for = release_time - press_time
    print("released at %s after %.2f seconds" % (release_time, pressed_for))
    if pressed_for < button.hold_time:
        # do stuff
def held():
    # do different stuff
button.when_pressed = pressed
button.when_released = released
button.when_held = held
pause()
Posted: Sat Sep 30, 2017 10:08 am
by elParaguayo
I guess I'm missing something here. Wouldn't active_time return the amount of time the button has been held while it is being held and, once the button is released, the relevant time is now in hold_time (and active_time is None as the button is now inactive)? If that's the case then comparing them doesn't make much sense to me.
I've never used gpiozero so I'm happy to be educated but I've taken a quick look at the source and docs and that's my understanding.
Posted: Sat Sep 30, 2017 10:54 am
by thagrol
held_time only counts "from the first execution of the when_held event" so will likely be None if the button is released before hold_time has passed. Or indeed once the button has been released at all.
You might have better luck with my code referenced above. (Store the time on press, compare to time on release and fire action depending on how much time has passed).
Posted: Sat Sep 30, 2017 11:03 am
by thagrol
Just my 2 cents worth but, because once the button has been released it's no longer active so active_time will be None?
Re: GPIOZero - 2 fonction for same GPIO ? [ SOLVED ]
Posted: Mon Oct 02, 2017 2:07 pm
by smalldragoon
HI
Thanks to all, specially to CyberGyver !
Obvisouly, the active_time is not a such usefull parameter... but at least I understand that everybody get it to none ;-)
Regarding the solution, I coded badly my value storage but with the code shared, works lovely !
Thx a lot again !
[ Edit] @ thagrol : yes, that's it ... tried to store the value , but improperly ... :roll:
Posted: Mon Oct 02, 2017 8:19 pm
by CyberGyver
I'm glad we could help. The python code is now on GitHub: https://github.com/CyberGyver/Raspberry ... eleased.py.
Posted: Tue Oct 03, 2017 4:47 pm
by smalldragoon
Thx !
