xanexxxx
Bluetooth (Blueterm app) Help!!
Sun Aug 13, 2017 9:45 am
I found this code online:
import bluetooth
import RPi.GPIO as GPIO        #calling for header file which helps in using GPIOs of PI
LED=21
GPIO.setmode(GPIO.BCM)     #programming the GPIO by BCM pin numbers. (like PIN40 as GPIO21)
GPIO.setwarnings(False)
GPIO.setup(LED,GPIO.OUT)  #initialize GPIO21 (LED) as an output Pin
GPIO.output(LED,0)
server_socket=bluetooth.BluetoothSocket( bluetooth.RFCOMM )
port = 1
server_socket.bind(("",port))
server_socket.listen(1)
client_socket,address = server_socket.accept()
print "Accepted connection from ",address
while 1:
 data = client_socket.recv(1024)
 print "Received: %s" % data
 if (data == "0"):    #if '0' is sent from the Android App, turn OFF the LED
  print ("GPIO 21 LOW, LED OFF")
  GPIO.output(LED,0)
 if (data == "1"):    #if '1' is sent from the Android App, turn OFF the LED
  print ("GPIO 21 HIGH, LED ON")
  GPIO.output(LED,1)
 if (data == "q"):
  print ("Quit")
  break
client_socket.close()
server_socket.close()
If i type "1" in blueterm app the LED turns on, "0" and it turns off, i was wondering if you know a way for Blueterm to READ code instead? Like:
"If pin 21 input = HIGH then print "stuff" in blueterm"?
Thanks!!
LetHopeItsSnowing
Re: Bluetooth (Blueterm app) Help!!
Mon Aug 14, 2017 7:27 am
Out of interest - what are you trying to do?
If you want to send data to the client (the blueterm app in this instance) you can use:
server_socket.send("hi")
It might also be worth putting a new line at the end:
server_socket.send("hi\n")
Whether the blueterm app is listening and will write data to the screen is a different matter - test it and find out.
"am I getting slower, or is stuff more complicated; either way I now have to write it down - stuffaboutcode.com"
xanexxxx
Mon Aug 14, 2017 7:32 am
Thank you i will try that!! And I'm trying to make a wireless motion detector. Here is my other thread if you're interested:
viewtopic.php?f=41&t=190348
Will report back once i tried your tips!
xanexxxx
Mon Aug 14, 2017 8:06 am
So I'm trying to make a simple script which will spam "motion detected" in blueterm as soon as i connect. Could anyone help me to write a script? Atm i have this:
import bluetooth
#LED=21
GPIO.setup(4,GPIO.OUT)  #initialize GPIO21 (LED) as an output Pin
port = 1
x = 1
while True:
  sleep(1)
  server_socket.send("MOTION DETECTED!")
  sleep(1)
But that won't really work.. I can't even connect with that haha (Yes I'm very new with Python).
LetHopeItsSnowing
Tue Aug 15, 2017 2:48 pm
Have you tested the program you have written?
What should happen is that it should run and wait for a connection.
When something (in this case the BlueTerm app) connects, the program will go into a loop sending the message to the app.
Is this what happens?
LetHopeItsSnowing
Tue Aug 15, 2017 2:50 pm
You will have to pair your Raspberry Pi and phone to allow Blue Term connect.
LetHopeItsSnowing
Tue Aug 15, 2017 2:58 pm
A module I have written "blue dot" http://bluedot.readthedocs.io/en/latest/ has a simple to use bluetooth comms api included in it, which might be easier to use.
You would have to install blue dot http://bluedot.readthedocs.io/en/latest ... arted.html, pair your Pi and your Phone [http://bluedot.readthedocs.io/en/latest ... droid.html], you could then use the btcomm api to create a simple bluetooth server.
The following code should (I havent tested it) wait for a connection and then spam a message back until it disconnects, if data is received, it will print it out to the screen:
from bluedot.btcomm import BluetoothServer
from time import sleep
def data_received(data):
    print("data received : " + data)
s = BluetoothServer(data_received)
#wait for a client to connect
while s.client_connected == False:
     sleep(0.1)
#keep sending the message hi while the client is connected
while s.client_connected == True:
    s.send("hi\n")
    sleep(1)
Return to “Python”
