jarnelramiscal
Re: Servo motor control with 4 PIR sensors using Raspberry Pi
Wed Mar 07, 2018 9:10 am
sir if i whant the servo he can revers if theres no motion how to put the code
pcmanbob
Wed Mar 07, 2018 11:42 am
The program was written to move the servo to were ever motion was detected and leave it there.
if you want to move the servo to a home position once no motion is detected you would need to change the loop that moves the servo on motion detection, so that if there is no motion the servo is driven to the required position.
So you would need to def a park function with the relevant p.ChangeDutyCycle line in it and any print line you wanted
then you need to change the 2,3,4 if's to elif and add an else: on the end to call the park function.
https://www.tutorialspoint.com/python/p ... f_else.htm
madscientist007
Wed Apr 04, 2018 1:39 pm
is it possible for someone to try this but using two ultrasonic distance sensor hc-sr04 instead of the PIR. i find the PIR to be very unreliable. thank you.
pcmanbob
Wed Apr 04, 2018 3:43 pm
If you want to test this using the HC-SR04 why not do it yourself ?
If I was to test it my environment would be totally different to yours so it may work for me but not you, if you are having problems you need to test in your environment to get any meaningful results.
seanwang
Mon Jul 15, 2019 8:30 am
so my project is a automated dust bin and it requires me to me to use one PIR sensor to run a servo motor may i know how should i code it ?
pcmanbob
Mon Jul 15, 2019 9:39 am
Hi.
There are lots of examples of how to use both the pir and a servo on the pi to be found on the web,
checking the raspberry pi web site would yield examples for both.
https://projects.raspberrypi.org/en/pro ... detector/3
https://projects.raspberrypi.org/en/pro ... a-scarer/4
B.Goode
Mon Jul 15, 2019 10:02 am
In addition to the resources referred to by @pcmanbob -
The gpiozero library, shipped by default as part of the Raspbian Operating System, has support for both these external devices. It provides a 'toolkit' of software components that can easily be used together.
Motion Sensor 2.17 https://gpiozero.readthedocs.io/en/stab ... ion-sensor
Servo 2.20 https://gpiozero.readthedocs.io/en/stab ... html#servo
(The project resources are probably using these basic components.)
Return to “Python”
