bsimpson888
Python Onewire OWFS
Mon Sep 10, 2012 7:54 am
Hello All,
I hope someone can help me here :-) I'am the proud owner of a RPi and try to communicate with a DS1820 temperature sensor. I'am using the bitbanging method via the Kernel-module to talk to that sensor and everything is working fine through the file handles in /sys.
Now to my problem. Instead of using these files I would like to use the python-ow library for OWFS. But in order to do this I need to have a correct owfs.conf telling the owfs system what onewire buses we have. And thats exactly where I'am lost. I googled a lot allready, but I can't find a hint how to setup the config file to use the kernel-module on the RPi as a onewire bus. I saw examples with usb-adapters and even DS2408 I2C Bus Masters, but not with the bitbanging kernel module like it is used in the adafruit occidentalis image.
I would be very happy if someone could help me or give me a push into the right direction.
Thanks in advance
Marco
sonite
Re: Python Onewire OWFS
Mon Sep 10, 2012 10:53 am
Very interesting question, I look forward to any replies. I my self tried and installed owfs and made everything online before realising that I could'nt find a way to do what you want to do.
Johan Vandewalle
Wed Aug 13, 2014 10:04 am
The owfs.conf file is located in /etc/owfs.conf.
This is the code of the file in my RPi. I didn't changed anything in it.
# Sample configuration file for the OWFS suite for Debian GNU/Linux.
# This is the main OWFS configuration file. You should read the
# owfs.conf(5) manual page in order to understand the options listed
# here.
######################## SOURCES ########################
# With this setup, any client (but owserver) uses owserver on the
# local machine...
! server: server = localhost:4304
# ...and owserver uses the real hardware, by default fake devices
# This part must be changed on real installation
#server: FAKE = DS18S20,DS2405
device=/dev/i2c-1
# USB device: DS9490
#server: usb = all
# Serial port: DS9097
#server: device = /dev/ttyS1
# owserver tcp address
#server: server = 192.168.10.1:3131
# random simulated device
######################### OWFS ##########################
#mountpoint = /mnt/1wire
#allow_other
####################### OWHTTPD #########################
http: port = 2121
####################### OWFTPD ##########################
ftp: port = 2120
####################### OWSERVER ########################
server: port = localhost:4304
Johan Vandewalle
(Belgium)
Return to “Python”
