smithjames0
Timer problem
Fri Nov 11, 2016 10:16 pm
Hi
I have a problem with a timer script, the timer function is triggered from another function. The problem I have is that the original function stops working for the length of time the timer is set for. I have googling but I am not quite sure what I need to looking for.
    def insidelight():
        GPIO.output(Coop.PIN_INSIDE_LIGHT, GPIO.HIGH)
        time.sleep(20)
        GPIO.output(Coop.PIN_INSIDE_LIGHT, GPIO.LOW)
    def checkTriggers(self):
        while True:
            (top, bottom) = self.currentTriggerStatus()
            if (self.direction == Coop.UP and top == Coop.TRIGGERED):
                logger.info("Top sensor triggered")
                GPIO.output(Coop.PIN_LED_R, GPIO.HIGH)
                GPIO.output(Coop.PIN_LED_G, GPIO.LOW)
                self.stopDoor(0)
            if (self.direction == Coop.DOWN and bottom == Coop.TRIGGERED):
                logger.info("Bottom sensor triggered")
                GPIO.output(Coop.PIN_LED_R, GPIO.LOW)
                GPIO.output(Coop.PIN_LED_G, GPIO.HIGH)
                self.stopDoor(1)
                self.insidelight()
Can anyone point me in the right direction? Thanks James
richrarobi
Re: Timer problem
Fri Nov 11, 2016 10:30 pm
Single threaded, i.e. sequential operation.
You need to investigate threading or multiprocessing so that your timed code can run separately.
smithjames0
Re: Timer problem
Mon Nov 14, 2016 10:02 pm
Thanks I have had a play, this is my code
        t5 = threading.Time(20.0, insidelight)
        t5.setDaemon(True)
  def insidelight(self):
             logger.info("Inside light on")
             time.sleep(20)
             logger.info("Inside light off")
             t5.stop()
        while True:
                self.stopDoor(0)
                self.stopDoor(1)
                t5.start()
but I get t5 = threading.Time(20.0, insidelight) NameError: global name 'threading' is not defined
can anyone suggest where I am going wrong?
Thanks James
elParaguayo
Re: Timer problem
Mon Nov 14, 2016 11:27 pm
Did you do a search for your error message. First hit on google seems to fix it.
I'm not trying to be mean, but python has pretty helpful error messages which should help you fix a lot of your problems. Learning to debug your own scripts is a key skill.
RPi Information Screen: plugin based system for displaying weather, travel information, football scores etc.
Return to “Python”
