Canedje
Conversion python 2 to 3.4
Fri Nov 04, 2016 8:39 pm
I do try to run a python2 programm with python 3 compiler.
I suddenly receive a lot of errors.
for example: st = time.time()
gives an error:
sudo python3 webserver.py
 File "webserver.py", line 23
    ts = time.time()
TabError: inconsistent use of tabs and spaces in indentation
I really don't understand what is wrong here.
Is there some tutorial showing the differents between Python 2 and 3?
Re: Conversion python 2 to 3.4
Fri Nov 04, 2016 8:44 pm
I think it is saying that you have some lines indented with space characters and some indented with tab characters and doesn't like the mix.
Canedje
Fri Nov 04, 2016 8:47 pm
Thanks.
So it is not allowed to mix both in the syntax of the line?
kusti8
Fri Nov 04, 2016 9:03 pm
Canedje wrote:Thanks.
Yes. I use an IDE where there's an option to convert all tabs to spaces, but this will work also:
sed 's/\t/    /g' tab-file.py > no-tab-file.py
Douglas6
Fri Nov 04, 2016 9:09 pm
There's also a program, 2to3, that tries to do the conversion automatically: https://docs.python.org/2/library/2to3.html
Canedje
Fri Nov 04, 2016 9:30 pm
Thanks this was the problem.
No I do have a new problem.
I'm using Tornado.
This was installed under Python2.7
Now under Python 3.4 it is not in the directory.
and generating the next error while compiling:
  File "webservertst.py", line 2, in <module>
    import tornado.httpserver
ImportError: No module named 'tornado'
I tried to reinstall tornado by:
python -m pip install tornado
With no result
How to install Tornado for Python 3.4?
kusti8
Fri Nov 04, 2016 9:33 pm
sudo pip3 install tornado
Canedje
Fri Nov 04, 2016 9:57 pm
Thanks again.
Again one step further.
Now I do receive an import error for:
   import MySQLdb as mdb
ImportError: No module named 'MySQLdb'
I quess i need to install Mysql for python 3.4?
I tried to reinstall mysql by using several methods without succes
Fri Nov 04, 2016 10:04 pm
You probably need to install python3-mysqldb
Canedje
Fri Nov 04, 2016 10:08 pm
I tried by using the next command:
sudo apt-get install python3-mysqldb
It said:
Package python3-mysqldb is not available, but is referred to by another package.
This may mean that the package is missing, has been obsoleted, or
is only available from another source
So this is not working
I also tried: sudo pip3 install pymysql
this gives:
Requirement already satisfied (use --upgrade to upgrade): pymysql in /usr/local/lib/python3.4/dist-packages
Cleaning up...
It suggest use upgrade
I did without result
I did find somewhere on the net:
Unfortunately MySQLdb does not support Python 3.
:cry:
So it looks like there is no solution
richrarobi
Sun Nov 06, 2016 10:24 am
This might help (from a quick Google) http://stackoverflow.com/questions/4960 ... -and-mysql
Stick at it, Python2 is fading (slowly, but it has an end of life plan, I believe) Python3 is better documented, etc, etc.
I decided to use python3 throughout, sometimes it is quite frustrating that code needs to be rebuilt.
I spent an evening converting an Adafruit library (stepper board control) then found someone had already done it (accidental search found it on github) !! Might stick with my own, though.....
Canedje
Sun Nov 06, 2016 10:32 am
Thanks. This is a help
Sun Nov 06, 2016 10:33 am
:cry:
https://pypi.python.org/pypi/mysqlclient
You'll be OK on 12th April 2020 @ 12:00GMT with that.
Note: Having anything remotely humorous in your signature is completely banned on this forum. Wear a tinfoil hat and you'll get a ban.
This is a doctor free zone.
Sun Nov 06, 2016 3:54 pm
Canedje wrote:I tried by using the next command:
this gives:
Cleaning up...
:cry:
Ah, I seem to have the Raspbian Stretch repository enable on the Pi I was checking that package on. That's why you can't see it in Raspbian Jessie.
Canedje
Sun Nov 06, 2016 3:56 pm
I indeeed now using pymysql
It is working fine
I changed my standard mysql import in:
import pymysql as mdb
mdb.install_as_MySQLdb()
After that it is running like mysql
Return to “Python”
