If calculation confusion - distance
Posted: Sun Jun 12, 2016 6:15 pm
by Mettauk
I have the following in a python script to measure distance
  def measure_average():
  # This function takes 3 measurements and
  # returns the average.
  distance1=measure()
  time.sleep(0.1)
  distance2=measure()
  time.sleep(0.1)
  distance3=measure()
  distance = distance1 + distance2 + distance3
  distance = distance / 3
  return distance
Then
try:
  while True:
    distance = measure_average()
    print "Distance : %.1f cm" % distance
    time.sleep(1)
except KeyboardInterrupt:
  # User pressed CTRL-C
  # Reset GPIO settings
  GPIO.cleanup()
I want to insert
    if distance()>= 5
    print 'words'
    end if
For some reason it does not like it? I get
~ $ sudo python ultra2.py
  File "ultra2.py", line 87
    if distance()>=5
SyntaxError: invalid syntax
Guessing i'm making a really simple error??
Re: If calculation confusion - distance
Posted: Sun Jun 12, 2016 6:30 pm
by DougieLawson
All conditional statements in python must end with a colon (:)
    if distance() >= 5:
Anything that's conditional must be indented by at least one space from the indentation level of the if statement
      print ("words")
There's also no scope terminators. So
    end if
is completely invalid.
Posted: Sun Jun 12, 2016 6:47 pm
by Douglas6
And distance is a variable, not a method, so use
if distance >= 5:
Posted: Sun Jun 12, 2016 6:56 pm
by stderr
Mettauk wrote:udo python ultra2.py
if distance()>=5
[/code]
The first thing to do is post things using the correct indentation since python requires that to even parse properly all other things being correct. According to a quick google, the python if construct looks like this:
if expression:
   statement(s)
else:
   statement(s)
Finally, what do you mean by "if distance()>=5"? Is "distance()" a function? It might help to put spaces between things as sometimes that is required.
Posted: Sun Jun 12, 2016 8:45 pm
by Mettauk
Thanks to you both, I think I was having a minor mind melt!
