swt4583
Threading for GPIO
Mon May 16, 2016 1:27 pm
Hey all,
I do not know much about threading in python but I thought since my project requires specific timing I figured I would try it out but I figured that I would ask first. I am trying to communicate to a One-Wire EEPROM using strickly GPIO pins since I have tried using the i2c bridge and it did not work. Also, I need my USB ports for other hardware. The problem is, is that python will execute each line approximately 50-100us and one wire requires communication down to the 1-10 us level so I was curious that if I try threading that I can execute the GPIO pins at this timing. Would this work? I am running Raspbian Wheezy. Thanks for your help :D
KnightOfPi
Re: Threading for GPIO
Tue May 17, 2016 5:19 am
i made similar experiments and it worked quite good, but i used https://docs.python.org/2/library/multiprocessing.html
instead of threading which really runs on different processors...
Check out www.knight-of-pi.org for many beginner-friendly tutorials!
Return to “Python”
