georgestewart88
Running script at boot, as root (or www-data?)
Tue Apr 19, 2016 10:12 am
Hi Everyone,
I am hoping you may be able to help. I have a log file that is updated by the user www-data through php. I want a script to run on boot that also updates this log, but the only way I can think of doing this is as root, since I can't log into www-data. Is there a way I can run a python script at boot, as root? or as www-data?
Thanks!
shuckle
Re: Running script at boot, as root (or www-data?)
Tue Apr 19, 2016 10:16 am
just put the script into /etc/rc.local, which is run by root during the boot.
Koeshi
Tue Apr 19, 2016 11:40 am
shuckle wrote:just put the script into /etc/rc.local, which is run by root during the boot.
Will this work for scripts that you want to run continuously during operation?
dbsteimle
Tue Apr 19, 2016 1:04 pm
Put an & after the script to run in the background:
/home/me/myscript.sh &
The "Temperature Log" lab is a good tutor for this. https://www.raspberrypi.org/learning/temperature-log/
David Steimle
http://davidsteimle.com/
Koeshi
Wed Apr 20, 2016 9:13 pm
dbsteimle wrote:Put an & after the script to run in the background:
That is just what I wanted, I have a python script putting out temperature readings to the PiGlow LED board, just wanted to have it going in the background without keeping a terminal window open.
Return to “Python”
