tintinmovie
Determine the location of a QR code in an image
Sun Apr 17, 2016 10:04 pm
For my science fair project, I'm going to read a QR code with a webcam connected to the Raspberry Pi B+ via USB cable. At the moment, I've got the RPI to take a picture, then read the QR code - using the library called Zbar. Python (that's the programming language I'm using) then prints the result into Python shell. Now I want Python to determine the location of the centre of the QR code, and print it out. Does anyone have any Python code I could use? Or does anyone recommend any libraries (apparently OpenCV takes a big chunk of your SD card so I don't want to use it unless it's the only option)?
Yours Sincerely,
TintinMovie :)
LetHopeItsSnowing
Re: Determine the location of a QR code in an image
Mon Apr 18, 2016 12:58 pm
A quick read about zbar and it suggests it will do it for you.
http://zbar.sourceforge.net/about.html
Have you tried just asking zbar to interpret the image for you.
"am I getting slower, or is stuff more complicated; either way I now have to write it down - stuffaboutcode.com"
Return to “Python”
