Varaldur
MPR121 capacitive touch hat in rapsberry
Wed Mar 02, 2016 4:40 pm
Hi
I would like creat a program with tkinter for use my raspberry hat mpr121 but when I try nothing function
scotty101
Re: MPR121 capacitive touch hat in rapsberry
Wed Mar 02, 2016 10:48 pm
Which board specifically did you buy?
It should be fairly easy to read the data over the i2c bus. Start with that and then worry about the Tkinter element.
Here is a code example that I wrote last week to access a simple i2c device and it has a GUI too.
https://github.com/scotty3785/python-blinkm
(It only writes to the i2c device so far)
williamhbell
Sat Apr 30, 2016 8:01 pm
If you are still stuck, then you could try:
https://github.com/williamhbell/MPR121CapSensor
This has been tested with the latest Raspbian version and works as expected. Installation instructions are given in the repository.
Best regards,
Will
Return to “Python”
