how to create backup of an SDB (sqlite3 database) file?
Posted: Wed Sep 25, 2019 7:14 pm
by ericg75
I have a SDB sqlite3 database file that collects weather-station data every half hour. I would like to know HOW to CREATE A BACKUP of this file, every day, preferably on another box, so that I will not loose all of my historical weather data (again). I do not have any experience with coding, but I can and do use sudo to other system related functions. I do enjoy my RASPBERRY PI's (I have two). Many thanks!
Re: how to create backup of an SDB (sqlite3 database) file?
Posted: Wed Sep 25, 2019 8:32 pm
by scruss
You're going to like this: SQLite databases are completely contained in that one file. You can copy them just like regular files. This is much less work than moving other databases around.
Posted: Wed Sep 25, 2019 11:02 pm
by DougieLawson
You do need to ensure there's no SQLite3 process running that has your database open.
With the sqlite3 command line program you can dump a database out as a bunch of SQL insert statements.
Dump:
cd /home/sqlite
sqlite3 sample.db .dump > sample.bak
Restore:
cd /home/sqlite
mv sample.db sample.db.old
sqlite3 sample.db < sample.bak
The restore could be done on any other machine with sqlite3 installed.
Posted: Thu Sep 26, 2019 1:31 am
by scruss
True enough. So a better way would be:
sqlite3 source.sdb ".backup 'destination.sdb'"
This has the same effect as copying the file, but ensures that the database is locked while copying so other processes can't corrupt it.
Posted: Thu Sep 26, 2019 4:33 am
by John_Spikowski
Dump:
cd /home/sqlite
Restore:
cd /home/sqlite
Thanks!
I have been looking for a SQLite export / import that works like phpmyadmin.
