vinnymoy
Problems installing Scilab.
Fri Jun 28, 2019 6:11 pm
Hello. I have a Pi 3B+ with Raspbian.
I need to use Scilab, then I use package include in the repository:
sudo apt-get install scilab
But, when I try to use it, the system give this message:
Picked up _JAVA_OPTIONS: -Djava.class.path=/usr/share/java/flexdock.jar:/usr/share/java/skinlf.jar:/usr/share/java/looks.jar:/usr/share/java/commons-logging.jar:/usr/share/java/jhall.jar:/usr/share/java/lucene-core-4.10.4.jar:/usr/share/java/lucene-analyzers-common-4.10.4.jar:/usr/share/java/lucene-queryparser-4.10.4.jar:/usr/share/maven-repo/org/freehep/freehep-util/debian/freehep-util-debian.jar:/usr/share/maven-repo/org/freehep/freehep-io/debian/freehep-io-debian.jar:/usr/share/maven-repo/org/freehep/freehep-graphicsio/debian/freehep-graphicsio-debian.jar:/usr/share/java/freehep-graphicsio-emf-2.1.jar:/usr/share/java/freehep-graphics2d-2.1.1.jar:/usr/share/java/jrosetta-API.jar:/usr/share/java/jrosetta-engine-1.0.4.jar:/usr/share/java/jgraphx.jar:/usr/share/java/jogl2.jar:/usr/share/java/gluegen2-rt.jar:/usr/share/java/jeuclid-core.jar:/usr/share/java/jlatexmath-fop-1.0.7.jar:/usr/share/java/fop.jar:/usr/share/java/saxon.jar:/usr/share/java/batik.jar:/usr/share/java/xml-apis-ext.jar:/usr/share/java/commons-io.jar:/usr/share/java/xmlgraphics-commons.jar:/usr/share/java/avalon-framework.jar:/usr/share/java/jlatexmath-1.0.7.jar:/usr/share/java/ecj.jar:/usr/share/java/javax.activation.jar:/usr/share/java/jaxb-runtime.jar:/usr/share/scilab/modules/javasci/jar/org.scilab.modules.javasci.jar:/usr/share/scilab/modules/jvm/jar/org.scilab.modules.jvm.jar:/usr/share/scilab/modules/graph/jar/org.scilab.modules.graph.jar:/usr/share/scilab/modules/scinotes/jar/org.scilab.modules.scinotes.jar:/usr/share/scilab/modules/graphic_objects/jar/org.scilab.modules.graphic_objects.jar:/usr/share/scilab/modules/ui_data/jar/org.scilab.modules.ui_data.jar:/usr/share/scilab/modules/action_binding/jar/org.scilab.modules.action_binding.jar:/usr/share/scilab/modules/helptools/jar/scilab_ru_RU_help.jar:/usr/share/scilab/modules/helptools/jar/scilab_en_US_help.jar:/usr/share/scilab/modules/helptools/jar/scilab_images.jar:/usr/share/scilab/modules/helptools/jar/org.scilab.modules.helptools.jar:/usr/share/scilab/modules/gui/jar/org.scilab.modules.gui.jar:/usr/share/scilab/modules/scirenderer/jar/scirenderer.jar:/usr/share/scilab/modules/core/jar/org.scilab.modules.core.jar:/usr/share/scilab/modules/xcos/jar/org.scilab.modules.xcos.jar:/usr/share/scilab/modules/renderer/jar/org.scilab.modules.renderer.jar:/usr/share/scilab/modules/preferences/jar/org.scilab.modules.preferences.jar:/usr/share/scilab/modules/graphic_export/jar/org.scilab.modules.graphic_export.jar:/usr/share/scilab/modules/types/jar/org.scilab.modules.types.jar:/usr/share/scilab/modules/history_manager/jar/org.scilab.modules.history_manager.jar:/usr/share/scilab/modules/external_objects_java/jar/org.scilab.modules.external_objects_java.jar:/usr/share/scilab/modules/completion/jar/org.scilab.modules.completion.jar:/usr/share/scilab/modules/localization/jar/org.scilab.modules.localization.jar:/usr/share/scilab/modules/console/jar/org.scilab.modules.console.jar:/usr/share/scilab/modules/commons/jar/org.scilab.modules.commons.jar:/usr/share/scilab/modules/history_browser/jar/org.scilab.modules.history_browser.jar:
WARNING: An illegal reflective access operation has occurred
WARNING: Illegal reflective access by org.scilab.modules.jvm.LibraryPath (file:/usr/share/scilab/modules/jvm/jar/org.scilab.modules.jvm.jar) to field java.lang.ClassLoader.sys_paths
WARNING: Please consider reporting this to the maintainers of org.scilab.modules.jvm.LibraryPath
WARNING: Use --illegal-access=warn to enable warnings of further illegal reflective access operations
WARNING: All illegal access operations will be denied in a future release
libEGL warning: DRI2: failed to authenticate
Error: No se puede crear una clase Main de Scilab.
Exception in thread "main" java.lang.InternalError: Available GLVersions not set for EGLGraphicsDevice[type .egl, v1.4.0, connection decon, unitID 0, handle 0x4cc28738, owner true, NullToolkitLock[obj 0x4906d3]]
at com.jogamp.opengl.GLProfile.initProfilesForDeviceCritical(GLProfile.java:1952)
at com.jogamp.opengl.GLProfile.initProfilesForDevice(GLProfile.java:1875)
at com.jogamp.opengl.GLProfile.initProfilesForDefaultDevices(GLProfile.java:1842)
at com.jogamp.opengl.GLProfile.access$000(GLProfile.java:80)
at com.jogamp.opengl.GLProfile$1.run(GLProfile.java:230)
at java.base/java.security.AccessController.doPrivileged(Native Method)
at com.jogamp.opengl.GLProfile.initSingleton(GLProfile.java:216)
at com.jogamp.opengl.GLProfile.getProfileMap(GLProfile.java:2297)
at com.jogamp.opengl.GLProfile.get(GLProfile.java:988)
at com.jogamp.opengl.GLProfile.getDefault(GLProfile.java:722)
at com.jogamp.opengl.GLProfile.getDefault(GLProfile.java:733)
at org.scilab.modules.gui.SwingView.<init>(Unknown Source)
at org.scilab.modules.gui.SwingView.registerSwingView(Unknown Source)
at org.scilab.modules.core.Scilab.<init>(Unknown Source)
Scilab no puede crear una clase Main de Scilab Java (no fuimos capaces de encontrar la clase main de Scilab. Revise si los paquetes de terceros de Scilab están disponibles).
I´m not an expert user, and I don't know what can I do.
neilgl
Re: Problems installing Scilab.
Sun Jul 14, 2019 10:32 am
Looks like a known bug in the version that is in the repository, so we need to wait for a fix/workaround.
tancl
Thu Aug 15, 2019 3:22 pm
I think there could be some missing lib related to opengl, a workaround is to use ubuntu for raspberry pi 3 and kali linux for raspberry pi 4.
Raspberry Pi 3
1. Use official ubuntu-server (hf) image
2. Install lubuntu-desktop (if you need Scilab GUI version)
3. Install scilab with apt-get install scilab
Raspberry Pi 4
1. Use kali linux image for raspberry pi
2. since it comes with desktop env, proceed with apt-get install scilab.
rgds,
CL
BR_Bruno
Fri Oct 04, 2019 7:26 pm
Hello, did you solve the problem?
clarc
Sat Nov 02, 2019 2:17 pm
Hello
Is it a new installation or an upgrade?
The Scilab package is available in the Univers repositories. Have you checked that this deposit is activated?
You can also adjust the return of this command:
dpkg -l scilab *
A +
