premsai
raspberry command for start video streaming to wowza
Mon Jun 24, 2019 10:22 am
present I am working with raspberry. using below command I am streaming video to a Wowza server.
"raspivid -o - -t 0 -w 1920 -h 1080 -fps 25 -b 4000000 -g 50 | /home/pi/ffmpeg -re -ar 44100 -ac 2 -acodec pcm_s16le -f s16le -ac 2 -i /dev/zero -f h264 -i - -vcodec copy -acodec aac -ab 128k -g 50 -strict experimental -f flv rtmp://your_RTMP_server_address/your_stream_key"
when I am entering this command in terminal automatically video popup is opening in the raspberry system but I don't want to play in the raspberry system, I want to stream to Wowza.
how to stop video popup in my raspberry server, what changes I need to change in the above command.
please help me
Thanks&Regards,
Kalpam.premasai.
ShaneP
Re: raspberry command for start video streaming to wowza
Wed Jul 03, 2019 6:05 pm
when I am entering this command in terminal automatically gimp freejobalert notepad++ video popup is opening in the raspberry system but I don't want to play in the raspberry system, I want to stream to Wowza.
please help me
Thanks&Regards,
Kalpam.premasai.
I also need help for the same. Help is appreciated.
Thanks in advance,
Regards,
Shane
