pnaven03
Securing SD card Image by encrypting in raspberry pi 3
Fri Apr 21, 2017 1:55 pm
Hi Team,
We are using Raspberry pi 3 and kernel version Linux raspberrypi 4.4.11-v7+ #888 SMP Mon May 23 20:10:33 BST 2016 armv7l GNU/Linux,How my sdcard image encrypting,this is for the security purpose please any one can help on this.
Regards,
Nv
mattmiller
Re: Securing SD card Image by encrypting in raspberry pi 3
Fri Apr 21, 2017 2:34 pm
Short answer is no - cant be done in any way that makes sense.
No way of securing a Pi image on an SD card that is of any practical use.
peterlite
Sat Apr 22, 2017 2:26 am
You cannot encrypt the Ext4 partition because the boot code in the FAT partition can not read an encrypted partition. You would have to split the Ext4 partition in two, one for the operating system and one for your encrypted data.
Big computers have encryption at the disk level because they have megabytes of BIOS running before booting the operating system. To do that, you need a big processor with a noisy fan or a dedicated encryption chip. $$$$
pnaven03
Sat Apr 22, 2017 10:03 am
Thanks for the reply,
What is the best method to provide security to my device,am disabling ssh,root access etc , but i need sdcard security also,
in sdcard loads my application code, if any other persons open sdcard he will not understand my code.
This is my costumer requirement , please any one help me on this.
Regards,
Nv
Sat Apr 22, 2017 10:49 am
pnaven03 wrote:... but i need sdcard security also, in sdcard loads my application code, if any other persons open sdcard he will not understand my code. This is my costumer requirement , please any one help me on this.
It's not possible.
This is a doctor free zone.
gordon@drogon.net
Mon Apr 24, 2017 5:31 pm
pnaven03 wrote:Thanks for the reply,
Regards,
Nv
You could re-partition the SD card and create a new empty, encrypted partition. Then you put all your applications and data in this partition with the rest of the usual/generic Raspbian in the first partition, as normal. You can also encrypt the whole / partition (but not the /boot partition). You can even do this on an already setup Pi.
Downsides -
(a) You/Someone will need to provide the password at boot time every time the Pi is booted. Unattended reboots will not be possible. This may or may not be acceptable to you or your client.
(b) It will be slower than it already is.
(c) google it - the first 2 links I got told me all I needed to know.
(d) You have not thought of this yourself. If I were your client, you'd be sacked by now.
First link on google: https://github.com/NicoHood/NicoHood.gi ... n-Tutorial
-Gordon
pnaven03
Tue Apr 25, 2017 9:09 am
Gordon,
client will not accept to enter the password.
if any other methods please provide me link.
Regards,
Nv
RaTTuS
Tue Apr 25, 2017 9:25 am
other ideas - all are defeatable
hot glue the sdcard into place
make tamper proof case
make the code work via a internet connection and only allow from authorized hosts
Covfefe
gordon@drogon.net
Tue Apr 25, 2017 12:52 pm
pnaven03 wrote:Gordon,
Regards,
Nv
Better still, we could bypass the middle-man and give your client my email address and I'll collect the fee...
-Gordon
RaTTuS
Fri Jul 07, 2017 1:44 pm
Covfefe
haggy
Fri May 18, 2018 6:11 pm
This looks really promising actually! Im also looking for an EFS solution for the RPi so I'll definitely be keeping up with zymbit.
le_
Mon Oct 14, 2019 7:01 am
Is it possible to use chroot with encryption?
Instead of encrypting the entire disk, it might be possible to encrypt a single partition. The raspbian system would boot normally, and then you could mount and load the chroot from the encrypted partition...
And anything that requires encryption protection could be transferred to chroot.
