clod
Re: Best code editor for ye HTML, CSS and JavaScript
Mon Sep 04, 2017 3:11 pm
My favorite HTML/CSS/JavaScript editor is Codelobster
Mon Sep 04, 2017 6:58 pm
I'm sure codelobster can be a fine editor.
Sadly it's not Open Source and it only runs on Windows.
Almost useless around here.
hunterzollomon
Fri Apr 20, 2018 6:16 am
i think that if you wish to code html,css and javascript on raspberry pi the best code editor will be the bluefish editor .i personally use that because it supports most of beginner programming language with auto correct option and syntax highlighting it is also very lightweight editor. so i recommend bluefish editor for html coding in raspberry pi
clod
Thu Aug 30, 2018 1:20 pm
Multiplatform version of CodeLobster IDE was released in April 2018.
Thu Aug 30, 2018 7:06 pm
Great stuff. That is half the problem solved.
mateorandulfe
Thu Nov 29, 2018 9:17 am
Hi, so personally I think Sublime Text is the best one. I have been using it during four years and it is so fast and flexible that cannot compare to others. There are so many things to point out that I think is better to leave you with a video I made reviewing Sublime and explaining its potential. :D
https://www.youtube.com/watch?v=Q-X1zoFniIo
DaveyDave1999
Tue Apr 16, 2019 10:06 pm
Geany is your best bet here. Syntax highlighting, compile buttons and more.
Lets not forget the fact that it comes preinstalled on full Raspbian ;)
Blog about Raspberries coming soon...
