hanako13
Problems with Linux Shell Scripts!
Wed May 04, 2016 9:49 am
Hi everyone,
I am just nearing the end of my Computing GCSE controlled assessment, and one of the questions is to write a shell script to automate adding new users and adding them to a group (in this case, either "teachers" or "students"). I found this website showing a script to add users with passwords, but I've copied it into a shell script on my Raspberry Pi, and I've got an error saying that I don't have permissions to run the program. I'm trying to run it from root@raspberrypi and I've used chmod -x to give execute permissions, but it's still not running.
Any ideas? I would really appreciate some help as the due date for the controlled assessment is this week! :? I'm the only girl in my class and none of the boys will help me... :(
13 forum two.png (7.54 KiB) Viewed 1242 times
13 forum one.png (24.79 KiB) Viewed 1242 times
jojopi
Re: Problems with Linux Shell Scripts!
Wed May 04, 2016 9:55 am
"chmod -x" removes execute permission. You want "chmod +x".
There are a couple of errors in the script as well. It is essential to have spaces inside the square brackets in lines like:
if [ $? -eq 0 ]; then
joan
Wed May 04, 2016 9:56 am
You have made the script non executable.
Try
chmod +x /usr/local/bin/addscript
hanako13
Wed May 04, 2016 6:15 pm
Thanks, I'll try using chmod +x and fixing the spacing problems in my next lesson and see how it goes. I'll let you all know if there's any more problems!
B.Goode
Wed May 04, 2016 7:05 pm
Since this is part of a controlled assessment, it would probably be wise to include a description of what problems you encountered and how you solved them.
Teachers and examiners read online forums too... !
experix
Thu May 05, 2016 12:49 pm
Was the assignment "understand the problem and write a program to solve it", or was it "find an answer somewhere on the web and copy it without understanding anything"?
hanako13
Thu May 05, 2016 6:59 pm
Yes, I've been sourcing any websites or tutorials that I've been using and writing about all the errors I've come across. Thanks for the tip!
I won't be copying the code directly into my assessment at all - the shell script I have been designing and writing myself to add users isn't working, and so I'm researching other people's scripts to understand how to write and fix my own.
