dch26
mouse support via gpm
Fri Jul 06, 2012 7:05 pm
i installed gpm: apt-get install gpm
started it: /etc/init.d/gpm start
and it works lovely in the console physically attached to the pi.
i can move a mouse cursor around, cut n paste text, etc.
however......when i launch an SSH session now, it is incredibly slow.
unusably so.
if i kill gpm: /etc/init.d/gpm stop
then the existing SSH session returns to warp speed.
read the docs for gpm, and cant see a flag to tell it not to affect remote sessions.
am i doing something wrong? pi-specific issue? user error? :)
cheers
dch
update - i have just realised that it is not just SSH sessions that it slows down. it also brings samba shares to their knees too......i will turn it off for now i think!!!
clickykbd
Re: mouse support via gpm
Sat Jul 07, 2012 1:56 am
I've got gpm running also... don't have samba configured (yet) but I haven't noticed the effects you speak of otherwise with ssh sessions.
Have you glanced at /var/log/messages to make sure your mouse itself isn't the culprit? I've had issues with USB devices including mice causing the network driver to freak out, lots of dwg_otg resets, among other things. The simplest commands take forever to execute in this state.
Do you notice these problems in X with the same mouse (but without gpm running)?
dch26
Sat Jul 07, 2012 9:48 am
thx for your reply clickykbd,
should have mentioned:
Linux pisces 3.1.9+ #138 PREEMPT Tue Jun 26 16:27:52 BST 2012 armv6l
(fully up to date)
when i start X, i do get erratic behaviour from my usb devices....keyboard in particular. it seems to repeat the last key i pressed (infinitely) - sometimes! (until i press another key to stop it). very annoying if you are trying to type a long command. i will try another keyboard/mouse set!
possibly troublesome hardware:
keyboard & mouse combo: LOGIK lwkbom10 (each claim 5v 100mA)
usb hub: LP7HUB11 (provides 5v 2A)
for some reason - i cant open "/var/log/messages" to answer your question. i'll have to look into why.
i'm sure you know this already - but for the benefit of others who may stumble on this thread:-
re: samba - just in case it' handy......this config (/etc/samba/smb.conf) shares the root and all below it:
[global]
   workgroup = WORKGROUP
   server string = Pi server
   dns proxy = no
   security = share
[homes]
   comment = Home Directories
   browseable = yes
   path=/
   read only = no
   create mask =  0775
   directory mask = 0775
   public = yes
   guest ok = yes
[printers]
   comment = All Printers
   browseable = no
   path = /var/spool/samba
   printable = yes
   guest ok = no
   read only = yes
   create mask = 0700
[print$]
   comment = Printer Drivers
   path = /var/lib/samba/printers
   browseable = yes
   read only = yes
   guest ok = no
;[cdrom]
;   comment = Samba server's CD-ROM
;   read only = yes
;   locking = no
;   path = /cdrom
;   guest ok = yes
if you dont want to share root (some would consider this dangerous - but when you are developing on a closed network.....then do as you wish!!) then you change the "path=/" in the "home" section, to the path you wish to share. eg "path=/home/raspbian"
then, just go to your windows pc and access \\pi-name or ip
i will report back on usb/gpm issue
cheers
dch
clickykbd
Sat Jul 07, 2012 1:46 pm
I'm not sure how you tried to view /var/log/messages, but try:
tail -f /var/log/messages
ctrl-c to quit watching it.
