scass0807
4 pin RGB LED
Thu Feb 12, 2015 10:42 pm
hi I'm trying to hook up a four pin RGB LED. I have the Canakit raspberry pi b+ ultimate starter kit and one RGB I can't figure out how to hook it up and program there are no tutorials and I already know how to hook up a regular
LED please help
mahjongg
Re: 4 pin RGB LED
Thu Feb 12, 2015 10:48 pm
What kind or RGB LED? If its just three LED's in a package with a common anode, then you can just treat it as if they were three separate LED's, but it might be something else altogether.
Do you have a data sheet of the RGB LED?
jimallyn
Re: 4 pin RGB LED
Thu Feb 12, 2015 10:57 pm
If the LED came with the Canakit, it should have documentation on it in the kit. If not, check their website, or contact them for more information. Or you can figure it out yourself: try applying a low voltage through a resistor to the leads in various combinations until you figure it out.
“So you say you love the poor? Name them.” - Gustavo Gutierrez
ame
Re: 4 pin RGB LED
Thu Feb 12, 2015 11:08 pm
I wonder what would happen if you typed "4 pin RGB LED" into Google?
scass0807
Re: 4 pin RGB LED
Fri Feb 13, 2015 1:29 am
mahjongg wrote:What kind or RGB LED? If its just three LED's in a package with a common anode, then you can just treat it as if they were three separate LED's, but it might be something else altogether.
No data sheet what about resistance
mikronauts
Re: 4 pin RGB LED
Fri Feb 13, 2015 1:34 am
I'd email Canakit support and ask them.
There both common anode and common cathode RGB LED's
There are also 4 lead WS2812b LED's
Best to ask them.
toxibunny
Re: 4 pin RGB LED
Fri Feb 13, 2015 1:50 am
most likely it's a plain rgb led. the longest lead is the common. get an aaa or aa battery and a bit of wire; bend the longest led lead so that you can hold it against one end of the battery without the other 3 leads getting in the way. do so. you should also press one end of the wire against the other end of the battery. you should now have the led, battery and wire together between your thumb and forefinger. this leaves your other hand free to touch the other end of the wire to the 3 remaining led pins. if nothing lights up at all, then turn the battery around...
note: I may or may not know what I'm talking about...
Re: 4 pin RGB LED
Fri Feb 13, 2015 1:57 am
Use a 560ohm (on each leg except the common anode / common cathode).
This is a doctor free zone.
davidcoton
Re: 4 pin RGB LED
Fri Feb 13, 2015 12:50 pm
toxibunny wrote:most likely it's a plain rgb led. the longest lead is the common. get an aaa or aa battery and a bit of wire; bend the longest led lead so that you can hold it against one end of the battery without the other 3 leads getting in the way. do so. you should also press one end of the wire against the other end of the battery. you should now have the led, battery and wire together between your thumb and forefinger. this leaves your other hand free to touch the other end of the wire to the 3 remaining led pins. if nothing lights up at all, then turn the battery around...
This may not work (LED forward voltage can be >1.5V), and worse still,may damage the LED. Use a higher voltage (at least 3V), and put a current limiting resistor between the battery and the common lead (usually the longest). The resistor should be at least 560 ohms, as per Dougie's post, but higher for higher voltage -- up to 10K for a 12V supply. The aim is to limit the current to a few milliamps.
RGB LEDS could be designed for use this way (with external current limiting), or could be designed for fixed voltage with internal current limiting. Assume the former until you know otherwise.
Signature retired
scass0807
Re: 4 pin RGB LED
Fri Feb 13, 2015 3:51 pm
How do I know which resistor colors have the amount of resistance I want.
davidcoton
Re: 4 pin RGB LED
Fri Feb 13, 2015 5:12 pm
scass0807 wrote:How do I know which resistor colors have the amount of resistance I want.
Here or other resources found by Uncle Google.
Signature retired
PiGraham
Re: 4 pin RGB LED
Fri Feb 13, 2015 5:34 pm
If you have a digital multimeter with diode test function you may find that connecting the probes one way will light the LED dimly. The current is limited and won't harm the LED if you connect it in reverse. Try the various combinations to see if there is common anode or common cathode and which lead is red, green or blue.
scass0807
Re: 4 pin RGB LED
Fri Feb 13, 2015 8:25 pm
Are there specific pins I should hook it up to or just any of the GPIO pins? I just bought resistors and male to female wires. Will 680ohms resistors work with a 4 Pin RGB without damaging the light or the Pi?
ame
Re: 4 pin RGB LED
Fri Feb 13, 2015 8:55 pm
Any GPIO is fine, as long as you know what number it is.
680 ohm resistors are also fine.
PiGraham
Re: 4 pin RGB LED
Fri Feb 13, 2015 9:49 pm
scass0807 wrote:Are there specific pins I should hook it up to or just any of the GPIO pins? I just bought resistors and male to female wires. Will 680ohms resistors work with a 4 Pin RGB without damaging the light or the Pi?
For identifying the leads use the 3.3v and GND pins.
scass0807
Re: 4 pin RGB LED
Sat Feb 14, 2015 1:46 am
Not the regular GPIO pins?
ame
Re: 4 pin RGB LED
Sat Feb 14, 2015 2:33 am
He means you can use it for testing. It's always on, so if you have it right your LED will light up. You can connect it to a GPIO later.
If you connect it to a GPIO now then you have make sure that GPIO is set properly.
scass0807
Re: 4 pin RGB LED
Sat Feb 14, 2015 3:36 pm
ame wrote: He means you can use it for testing. It's always on, so if you have it right your LED will light up. You can connect it to a GPIO later.
What do you mean if the
GPIO pins are set properly? Does that mean if I connect it to the GND pins or 3.3V pins it will light up automatically with no programing needed because the pins are always on?
PiGraham
Re: 4 pin RGB LED
Sat Feb 14, 2015 3:46 pm
Yes, 3.3V and GND are always on. They are power pins rather than IO pins. No programming required for the test. Once you have the LED figured out then connect it to GPIO pins to control it from software.
Of course you can use a GPIO pin for the test, if you program it to be on (output and set high, or low) but that's an extra variable.
imperialex
Re: 4 pin RGB LED
Mon Jun 18, 2018 9:54 pm
From Canakit website (https://www.canakit.com/triple-output-l ... 00105.html)
Wiring example states 1x180 ohms and 2x100 ohms
http://wiring.org.co/learning/basics/rgbled.html
Return to “Advanced users”
