xeonpeacemaker
Duel video output
Wed Oct 29, 2014 9:00 pm
Can i have 2 separate video outputs on the B+?
“Ford!" he said, "there's an infinite number of monkeys outside who want to talk to us about this script for Hamlet they've worked out.”
― Douglas Adams, The Hitchhiker's Guide to the Galaxy
mahjongg
Re: Duel video output
Thu Oct 30, 2014 12:23 am
Actually, and perhaps surprisingly, yes you can!
You can use the HDMI/DVI-D port for one monitor, and then use Gert's VGA adapter for a VGA monitor, both screens act independently from each other, so can display different contents.
http://www.raspberrypi.org/gert-vga-adapter/
In the future the Raspberry PI Foundation will bring out a DSI (display serial interface) LCD panel, that can also be used independently from the HDMI interface.
drgeoff
Thu Oct 30, 2014 10:34 am
xeonpeacemaker wrote:Hello,
If you mean HDMI and composite simultaneously, no.
xeonpeacemaker
Thu Oct 30, 2014 11:56 am
I meant the HDMI and the ribbon lcd connection thats on the board
Burngate
Thu Oct 30, 2014 12:28 pm
In that case, not yet.
Some time in the near future, an official DSI LCD will be released, then you can have dueling screens - pistols at 20 paces ... oh, you meant dual. ;)
Joe Schmoe
Thu Oct 30, 2014 2:41 pm
mahjongg wrote:Actually, and perhaps surprisingly, yes you can!
Yes. If only the Gert VGA board actually existed (as a consumer product)…
P.S. Re: the DSI/LCD screen. Even though the Foundation hasn't yet released the so-called "official" screen, it is still the case (AIUI) that you can find and buy something on your own and hook it up and it will work.
Which is, not entirely coincidentally, exactly the same as the situation with the Gert VGA board. It's not (yet) available as a consumer product, but if you can somehow get hold of one, it will work.
Gert van Loo
Thu Oct 30, 2014 4:40 pm
Just give it time.
Joe Schmoe
Thu Oct 30, 2014 6:03 pm
Just give it time.
Thank you. I am glad to hear that.
(I.e., I would really like to have one to play with, but I don't trust my soldering skills)
xeonpeacemaker
Fri Oct 31, 2014 6:19 am
Off topic, can i get 2 or more Pi's to talk to each-other via Ethernet/usb?
Fri Oct 31, 2014 6:42 am
xeonpeacemaker wrote:Off topic, can i get 2 or more Pi's to talk to each-other via Ethernet/usb?
http://www.raspberrypi.org/documentatio ... /README.md
adieu
Asus CS10 Chromebit / HP Envy 4500 Wireless Printer / Raspberry Pi Model 2B v1.1 / RealVNC Software...
Fri Oct 31, 2014 8:21 am
Don't even bother with looking at USB, the easiest way is with TCP/IP (or UDP/IP). Search the forum for "MQTT" or "Mosquitto", MQTT is the protocol for the Internet of Things and Mosquitto is the broker that makes MQTT happen.
Note: Having anything remotely humorous in your signature is completely banned on this forum. Wear a tinfoil hat and you'll get a ban.
This is a doctor free zone.
Jim JKla
Fri Oct 31, 2014 8:32 am
There is a way to have multiple screens under the control of one RPi but you also need a RPi for each screen.
You can use PiWall and theoretically if you are prepared to accept delays there's a posibility of making the screens wireless and then use model "A" RPi's and nano Wifi. You understand this is theoretical and the the communication delays may make the system unuseable but it is theoreticaly possible.
It depends on wether your aim is for a multiscreen system per say or just trying to get one RPi to do a lot.. ;)
Return to “Advanced users”
