audetto
USB audio: any luck?
Sun Mar 16, 2014 1:12 pm
I've been trying for a while to setup my Pi as an Internet Radio player.
I use mpd and internal audio.
Then, I decided to use a PS3 controller via bluetooth as a remote control and got a lot of issues, which seem to be resolved (so far so good) by the latest FIQ usb rewrite.
But in the meantime I gave a go to a USB sound card (https://www.modmypi.com/raspberry-pi-ac ... nd-adapter, the CM108 version), and found a number of issues
1) reboots Pi if hotplugged to Pi directly (ok if plugged before boot)
2) appalling audio if connected to a usb hub
3) kills the network stack with intense NFS traffic (https://github.com/raspberrypi/linux/is ... t-37737253), (when minidlna rescans the database)
4) glitches more often than not
I seem to understand that this is a USB 1 device, which needs a Multi TT hub to work well and so on.
Many people report success with USB audio, but maybe their Pi is not loaded too much?
Would I have a better result with a real USB 2 device? Can't find any. All the ones I found are USB 2 Full Speed (12Mb/s), which smells the same as USB 1.
(see http://www.amazon.co.uk/USB2-0-External ... VEZQUSFYSM)
So now, I reverted to internal audio, much better.
Am I just unlucky with a dodgy device? dodgy Pi? or this is expected once the system gets loaded doing many things and using very cheap devices?
Anybody has similar (or opposite) stories?
Return to “Advanced users”
