craizy
Same chip for sd card and usb?
Fri Jun 28, 2013 12:38 pm
So I have this PI set up a sa download box and I get crap transfer speeds to my computers.
I have my OS on a usb stick, my wifi dongle on a usb stick and my hard drive on a usb stick.
Would I get better speeds at transfert with OS on the sd card and my internet over ethernet leaving the usb only for the hard drive?
Thank you!
RaTTuS
Contact: Twitter YouTube
Re: Same chip for sd card and usb?
Fri Jun 28, 2013 12:53 pm
what speeds are you getting
Covfefe
craizy
Fri Jun 28, 2013 1:15 pm
I'm getting like 4megabytes/s peak and like 3.2 avg on a large file (10GB)
hojnikb
Fri Jun 28, 2013 2:16 pm
seems pretty normal.. You could get more with ethernet and samba tweaks but remeber, rpi doesnt have native ethernet, so everything is shared via usb...
+°´°+,¸¸,+°´°~ Everyone should have a taste of UK Raspberry Pie =D ~°´°+,¸¸,+°´°+
Rasberry Pi, SoC @ 1225Mhz :o, 256MB Ram @ 550Mhz, 16GB SD-Card, Raspbian
craizy
Fri Jun 28, 2013 2:33 pm
Is the sd card shared with usb too?
portets
Fri Jun 28, 2013 8:38 pm
No, and USB sticks tend to be very slow. Sometimes slower than SD cards.
Have you overclocked your Pi? This helps mine.
My Pi with OS on a USB3.0 stick and overclocked to 1100arm/600sdram/500core transfers files at about 10-20MB/s.
craizy
Fri Jun 28, 2013 8:50 pm
Yeah my Pi has the same set-up as you, except with the wifi dongle.
I hope it will get better once I receive my gigabit switch.
OtherCrashOverride
Sat Jun 29, 2013 12:04 pm
craizy wrote:I hope it will get better once I receive my gigabit switch.
The Raspberry Pi is a 10/100 ethernet device. It can not do gigabit ethernet. Unless your current switch is slow or overloaded, you will have the exact same performance.
craizy
Sat Jun 29, 2013 4:19 pm
Well actually right now im on a wifi dongle with 300mbps rated
technion
Sun Jun 30, 2013 5:24 am
300
I believe you'll find that's faster than the shared USB bus will download files then write them to your USB disk.
RaTTuS
Mon Jul 01, 2013 8:38 am
usb2 is 480mbps
Covfefe
Mon Jul 01, 2013 8:52 am
RaTTuS wrote:usb2 is 480mbps
480 millibits? Strewth, that's slow... ;)
So assume about half of that 480Mb/s is being used for the USB disk and half for network. Then allow for USB protocol overheads and other stuff. Be lucky to get 100Mb/s usable throughput.
technion
Mon Jul 01, 2013 10:42 am
So assume about half of that 480Mb/s is being used for the USB disk and half for network..
Yeah I should have clarified. Once you're sharing a 480MB USB bus with a 300MB WLAN and a HDD, you can't expect 300MB on the WLAN.
I haven't seen any performance tests on how well the Pi could actually manage wifi encryption, and I'd be interested in whether anyone can get 300MB on something like iperf.
Return to “Advanced users”
