Acces /dev/mem with the apache2 user
Posted: Sat May 04, 2013 9:38 pm
by tomazzs
Hi all,
I have a project that requires acces to /dev/mem in order to change GPIOs. I made a website on a apache2 webserver on the PI, this website has to execute a python script to control a steppermotor. The user of the Apache2 webserver is www-data. But when I execute the python script by www-data, I get this error: "No access to /dev/mem. Try running as root!".
I know it's a big security risk to set the root as the Apache2 user, so that's not an option.
My question is; how would this be done properly, enabling the user www-data to execute the python script to controll the steppermotor from the apache2 webserver?
Thanks in advance,
T
Re: Acces /dev/mem with the apache2 user
Posted: Sun May 05, 2013 12:36 am
by jojopi
In UNIX, if a program has the set-user-id permission (chmod u+s) then when executed it starts as the user who owns the program file, instead of the user whom the parent process was running as. This is the usual method of escalating privilege.
For security reasons, set-user-id is only allowed on compiled binary programs, and not on scripts. So you want a set-user-id wrapper written in C that can elevate privilege and then start the Python script.
Luckily there is already a very configurable set-user-id wrapper program installed: sudo. You can use "sudo visudo" and add a line at the bottom such as:
www-data ALL=(root) NOPASSWD: /usr/bin/python /usr/local/bin/script.py *
This allows www-data to run that specific python script as root, with any arguments, using "sudo python /usr/local/bin/script.py …". It does not allow privileged access to any other scripts or commands, so it is relatively secure.
The script still needs to be written carefully to ensure that it cannot be tricked into performing unintended operations. Ideally it should drop root privileges as soon as it has opened /dev/mem, but I do not think RPi.GPIO makes that easy.
Note that www-data should not have write access to the script, or any of its parent directories, or it could install its own instructions and then run them as root.
Posted: Sun May 05, 2013 6:07 pm
by tomazzs
Thank you very much, that's the solution! :D
Posted: Sun May 12, 2013 4:08 pm
by tom.k.cook
Can I just note that giving apache write access to raw memory is dreadful security practice?
Better practice by far to have two processes; one with access to GPIO, one facing the web, with a suitable IPC mechanism between them.
My $0.02.
Posted: Mon Jun 24, 2013 9:43 pm
by mikemitza
Hello. I have the same problem that tomasz had, I managed to get the permissions right but I have a new error:
sudo: no tty present and no askpass program specified
I found this in the apache log. Does anyone know any solutions?
Posted: Tue Jun 25, 2013 12:12 am
by jojopi
mikemitza wrote:sudo: no tty present and no askpass program specified
Your sudo configuration evidently requires a password to be given. There is no way to ask the apache user to type a password (and the account probably does not have one) so you must use the NOPASSWD tag in the relevant sudoers line.
tom.k.cook wrote:Can I just note that giving apache write access to raw memory is dreadful security practice?
This thread is specifically about not giving the apache process itself any additional privileges. You solution with a persistent privileged co-process, instead of transient privileged children, is more efficient but not necessarily any more secure.
Posted: Sat Jun 29, 2013 6:48 am
by ghp
I have solved this problem in a different way.
As I did not like the idea, that front end apache gets access to some root stuff (professional paranoia), I implemented a background process running with root privileges. Communication with apache applications is by a local socket.
The advantages are
  • - Structure: there is a clean definition of which commands are allowed, say "LED_ON", "LED_OFF", "LED_BLINK" (I send the commands in ascii)
    - Testability. It is easy to test the application step by step. Background process is validated by a local telnet session, and the web application can be tested by printing the incoming commands in the background process.
    - Concurrency. In a web app, there could be many users in parallel. Giving access to a single instance of local hardware will need synchronization, queuing or whatever needed. This is usually simpler to handle in a background process.
Disadvantage is the slightly higher overhead.
Greetings,
Gerhard
Posted: Sat Jun 29, 2013 7:35 am
by jojopi
ghp wrote:Disadvantage is the slightly higher overhead.
Actually your method is almost certainly more efficient. The overhead of starting a new process is much higher than passing a message over a socket.
I agree that a persistent co-process may be necessary if you need to control the serialization of requests, as well. I do not see that validating or testing the commands passed though a socket is any easier than those passed as command line arguments.
Incidentally, if you care about security you should probably try to eliminate any use of /dev/mem. The /sys/class/gpio interface allows access to most GPIO functionality and, after initial export and setting of permissions, does not require root privilege. Furthermore, you can set permissions individually for different GPIO pins, including controlling whether users can change the direction of a pin or only read/write the value.
Failing that, after opening /dev/mem you can drop root privileges, map only the specific registers you need to access, and then close /dev/mem before parsing any commands from your clients.
Posted: Sun Jun 30, 2013 5:30 am
by technion
ghp wrote:Hello,
I'd be interested in the source code to this. Is it available?
Posted: Sun Jun 30, 2013 3:29 pm
by ghp
Hello, some source code.
The idea was to have a background process, executing commands coming in by a socket connection.
I used this in a setup, where a LED and a RGB-LED should be controlled by a web server.
What you might find: the code is not very consistent in logging and the ioHandler idea was to encapsulate the IO-Access from the business logic. But the rgb-Thread directly controls IO, which violates this principle.
Server side:
#!/usr/bin/python3
# -*- coding: utf-8 -*-
# Controlling one LED ON, OFF, BLINK.
# Controlling a RGB-LED with software PWM.
# Preparation in system:
#   For Test only
#     install telnet client and check localhost 9999
#     apt-get install telnet
# Start process as root, the led blinks some time in order to indicate
# that process is running.
# Socket commands are
# 'ON'        --> turn LED on
# 'OFF'       --> turn LED off
# 'BLINK'     -- blink LED
# RGB<r>,<g>,<b>  --> Switch RGB values, control by pwm.
#                     Example RGB20,200,100
# The upper cas commands close the connection.
# The lower case commands on, off, blink and rgb keep the socket connection open,
# what is simpler for debug purpose.
# THE ON, OFF-Commands perform the action immediateley. The BLINK and RGB issue a thread
# which keeps until new commands arrive.
# Testing: open a telnet session 'telnet localhost 9999' and issue e.g. 'ON', 'OFF', 'BLINK'.
import socketserver
import time
import threading
import RPi.GPIO as GPIO
import re
GPIO.setmode(GPIO.BCM)
GPIO.setwarnings(False)
debug = False
class IOHandler:
    LED = 23
    def __init__(self):
        GPIO.setup(self.LED, GPIO.OUT)
    def led_on(self):
        global debug
        GPIO.output(self.LED, True)
        if debug:
            print('led_on')
    def led_off(self):
        global debug
        GPIO.output(self.LED, False)
        if debug:
            print('led_off')
class RGBThread (threading.Thread):
    r = 40
    g = 40
    b = 40
    R = 22
    G = 18
    B = 17
    runIt = None
    def __init__(self):
        threading.Thread.__init__(self)
        GPIO.setup(self.R, GPIO.OUT)
        GPIO.setup(self.G, GPIO.OUT)
        GPIO.setup(self.B, GPIO.OUT)
        self.runIt = True
    def setRGB(self, r,g,b):
        self.r=r
        self.g=g
        self.b=b
    def run(self):
        global debug
        if debug:
            print('RGBThread.run')
        k = 30000
        while self.runIt:
            GPIO.output(self.R, True)
            time.sleep(self.r / k)
            GPIO.output(self.R, False)
            time.sleep((256-self.r)/k)
            if self.runIt == False:
                break
            GPIO.output(self.G, True)
            time.sleep(self.g / k)
            GPIO.output(self.G, False)
            time.sleep((256-self.g)/k)
                break
            GPIO.output(self.B, True)
            time.sleep(self.b / k)
            GPIO.output(self.B, False)
            time.sleep((256-self.b)/k)
                break
        print("RGBThread.runit finished")
class BlinkThread(threading.Thread):
    runIt = None
    def __init__(self):
        self.runIt = True
    def run(self):
        global ioHandler
        while self.runIt:
            ioHandler.led_on()
            for i in range(20):
                    break
                time.sleep(0.05)
                break
            ioHandler.led_off()
            for i in range(20):
                    break
                time.sleep(0.05)
        print("BlinkThread.runit finished")
class PWMThread(threading.Thread):
    runIt = None
    def __init__(self):
        self.runIt = True
    def run(self):
        global ioHandler
        kk = 2000
        while (self.runIt):
            # iNNN are the values to set
            iMax = 32
            for i in range (iMax):
                for k in range(5):
                    ioHandler.led_on()
                    time.sleep(i/kk)
                        break
                    ioHandler.led_off()
                    time.sleep((iMax-i)/kk)
                        break
                    break
            for i in range (iMax-1,1,-1):
                for k in range(5):
                    ioHandler.led_on()
                    time.sleep(i/kk)
                        break
                    ioHandler.led_off()
                        break
                    break
        print("PWMThread.runit finished")
thread = None
rgbThread = None
class MyTCPHandler(socketserver.BaseRequestHandler):
    The RequestHandler class for our server.
    It is instantiated once per connection to the server, and must
    override the handle() method to implement communication to the
    client.
    def stopThread(self):
        global thread
        print("stopThread")
        if thread != None:
            thread.runIt = False
            print("wait for join")
            thread.join()
            thread = None
        print("stopThread ok")
    def startThreadBlink(self):
        global thread
        thread = BlinkThread()
        thread.start()
    def startThreadPWM(self):
        global thread
        thread = PWMThread()
        thread.start()
    def handle(self):
        global rgbThread
        ##self.request.sendall(b"welcome\n")
        while(True):
            # self.request is the TCP socket connected to the client
            self.data = self.request.recv(1024)
            if len(self.data) == 0:
                break
            self.data = self.data.strip()
            print ("{} wrote:".format(self.client_address[0]))
            print( self.data)
            if self.data.startswith(b'on'):
                self.request.sendall(b"switch it on\n")
            if self.data.startswith(b'ON'):
                self.stopThread()
                ioHandler.led_on()
                break
            if self.data.startswith(b'off'):
                self.request.sendall(b"switch it off\n")
            if self.data.startswith(b'OFF'):
                self.stopThread()
                ioHandler.led_off()
                break
            if self.data.startswith(b'BLINK'):
                self.stopThread()
                self.startThreadBlink()
                self.request.sendall(b"blink multiple\n")
                break
            if self.data.startswith(b'PWM'):
                self.stopThread()
                self.startThreadPWM()
                self.request.sendall(b"pwm\n")
                break
            if self.data.startswith(b'RGB'):
                if rgbThread == None:
                    rgbThread = RGBThread()
                    rgbThread.start()
                regex =     r"RGB,([0-9.]+),([0-9.]+),([0-9.]+)"
                data = self.data.decode("iso-8859-1")
                m = re.match(regex, data)
                if m == None:
                    print('could not parse ' + data + ' with ' + regex)
                else:
                    dr = int( m.group(1) )
                    dg = int( m.group(2) )
                    db = int( m.group(3) )
                    rgbThread.setRGB(dr,dg,db)
                self.request.sendall(b"rgb\n")
                break
            # just send back the same data, but upper-cased
            self.request.sendall(self.data.upper())
ioHandler = IOHandler()
def main():
    # some startup action, just for fun
    for i in range(10):
        ioHandler.led_on()
        time.sleep(0.2)
        ioHandler.led_off()
        time.sleep(0.2)
    HOST, PORT = "localhost", 9999
    # Create the server, binding to localhost on port 9999
    server = socketserver.TCPServer((HOST, PORT), MyTCPHandler)
    # Activate the server; this will keep running until you
    # interrupt the program with Ctrl-C
    server.serve_forever()
if __name__ == "__main__":
    print('start')
    main()
Testing, as indicated, with a telnet session.
A python client is:
#!/usr/bin/python3
import socket
import sys
data = " ".join(sys.argv[1:])
# Create a socket (SOCK_STREAM means a TCP socket)
sock = socket.socket(socket.AF_INET, socket.SOCK_STREAM)
try:
    # Connect to server and send data
    sock.connect((HOST, PORT))
    ## received = sock.recv(1024)
    sock.sendall(bytes(data + "\n", 'UTF-8'))
    # Receive data from the server and shut down
finally:
    sock.close()
print ("Sent:     {}".format(data))
print ("Received: {}".format(received))
Next a simple cgi-script which uses the background process.
#!/usr/bin/python3
import cgi
import cgitb
cgitb.enable
import socket
def generate_form():
    print ('Content-Type: text/html\n\n')
    print ("<HTML>")
    print ("<HEAD>")
    print ("<TITLE>LED Form</TITLE>")
    print ("</HEAD>")
    print ("<BODY BGCOLOR = white>")
    print ("<H1>LED Status auswaehlen.</H1>")
    print ("<FORM>")
    print ("<SELECT size = '7' name = 'led' style='font-size:14'>")
    print("   <option>off</option> ")
    print("   <option>on</option> ")
    print("   <option>blink</option> ")
    print("   <option>pwm</option> ")
    print("   <option>rgb red</option> ")
    print("   <option>rgb green</option> ")
    print("   <option>rgb blue</option> ")
    print("</SELECT>")
    print ("<INPUT TYPE = hidden NAME = 'action' VALUE = 'ledstatus'>")
    print ("<INPUT TYPE = submit VALUE = 'Enter' style='font-size:14'>")
    print ("</FORM>")
    print ("</BODY>")
    print ("</HTML>")
    print("last")
def socketServer(what):
    data = 'BLINK'
    if what == 'on':
        data = 'ON'
    if what == 'off':
        data = 'OFF'
    if what == 'blink':
        data = 'BLINK'
    if what == 'pwm':
        data = 'PWM'
    if what == 'rgb red':
        data = 'RGB,255,0,0'
    if what == 'rgb green':
        data = 'RGB,0,255,0'
    if what == 'rgb blue':
        data = 'RGB,0,0,255'
    received = 'no data received'
    try:
    except Exception as e:
        print('unexpected problem: ' + str(e))
    finally:
        sock.close()
    print ('<html>')
    print ('<head>')
    print ('gpio-page')
    print ('</head>')
    print ('<body>')
    print ('gpio switched')
    print ("<pre>")
    print ("</pre>")
    print ("<br/>")
    print ("<a href='cgi_3.py'>zurueck</a>")
    print ('</body>')
    print('</html>')
# Define main function.
def main():
    form = cgi.FieldStorage()
    if ("action" in form  and "led" in form  ):
        if (form["action"].value == "ledstatus"):
            socketServer(form["led"].value)
    else:
        generate_form()
# Call main function.
main()
Greetings, Gerhard
