supertramp1966
Teather phone to RPI to create a network? Is it possible.
Tue Jan 21, 2020 12:24 pm
I have been trying to solve a situation I have! I have a Unlimited Data plan on my cell (true unlimited!!) I just moved to a place with no Land based Internet! Except for Verizon DSL @ .09 - 1.2 down for $80 a month YUCK! I Own a RPI 3b+ and 2 RPI 4 2 Gig, I want to get another phone just to teather via USB but don't want to drop $300+ on a Mofi device! Is there a way to teather a Android phone via USB to a RPI to create a network? I ultimately want to use the Ethernet Port to connect to mesh router because several devices I have are Ethernet only like my Phillips Hue Hub And obi Google voice box. Thanks
epoch1970
Re: Teather phone to RPI to create a network? Is it possible.
Tue Jan 21, 2020 7:41 pm
supertramp1966
Wed Jan 22, 2020 7:00 am
So now that I know it's possible is there any information out there on how to set it up in my situation? I found this article but I'm not sure if it's what I need? https://www.raspberrypi.org/forums/view ... p?t=214536
Any help pointing me to a How To would be great :) plus what I found wasn't really a How To just that someone managed to set up something similar.
I am really Rusty with my Linux!
supertramp1966
Fri Jan 24, 2020 7:36 am
That works but I still need to use the Ethernet to connect to a Router basically I want to use a PI as a modem like the Mofi devices they let you connect a Android or iOS Phone to a USB port and then you can connect a Router to one of it's Ethernet Ports acting as a bridge between the phone and the router.
Return to “Advanced users”
