rin67630
Avoiding circular symlinks in an install script
Sun Aug 18, 2019 4:25 am
I am writing an install script:
sudo cp autoreset /usr/bin
sudo cp avrdude-autoreset /usr/bin
sudo mv /home/pi/arduino-1.8.8/hardware/tools/avr/bin/avrdude /usr/bin/avrdude-original
sudo ln -s /usr/bin/avrdude-autoreset /home/pi/arduino-1.8.8/hardware/tools/avr/bin/avrdude
sudo chmod 755 /usr/bin/avrdude-autoreset
sudo chmod 755 /usr/bin/autoreset
The script is replacing the original program /home/pi/arduino-1.8.8/hardware/tools/avr/bin/avrdude by a symlink.
The problem is that, if you run that script a second time...
will create a circular symlink and the avr will crash.
Has someone got a clue on how to prevent that?
Re: Avoiding circular symlinks in an install script
Sun Aug 18, 2019 4:52 am
Use a hard link instead of a symlink?
rin67630
Sun Aug 18, 2019 5:03 am
In the original program? Funny.
Why do you think the whole procedure was done that way?
nigelbartlett1
Sun Aug 18, 2019 7:23 am
First make your script a Bash script by adding, as first line
#!/bin/bash
Then, prior to creating a symlink, test whether it (doesn’t) exist and create it in that event only
if [ ! -L linkname ]; then
  sudo ln ...
fi
epoch1970
Sun Aug 18, 2019 7:59 am
Pray tell, what is wrong with hard links? Except they are less notorious than soft links, that is.
rin67630
Sun Aug 18, 2019 8:03 am
  sudo ln ...
fi
Thank you, that is the approach that I expected.
Could you please give me the concrete example of how to specify the linkname?
The stuff with links (e.g. deleting them) is a bit confusing. Inside a negative if statement, can easily lead to unwanted results if the syntax has an error.
Regards
rin67630
Sun Aug 18, 2019 8:24 am
They must be on the same inode, which is not the case.
Sun Aug 18, 2019 8:40 am
Well, looking at that script I'd say it was because you need to learn more about writing scripts.
epoch1970
Sun Aug 18, 2019 8:44 am
Hard links do not “must”, point to the same inode as the original file, they do by nature.
I don’t see that should be a problem.
Perhaps you meant to say the files are not on the same device, hence you cannot use hard links?
rin67630
Sun Aug 18, 2019 9:01 am
No, they are not in the same inode.
Sun Aug 18, 2019 9:06 am
Well, of course different files are not in the same inode. But if you delete one of them and create a hard link then they will be.
rin67630
Sun Aug 18, 2019 9:56 am
The very purpose of the thing is to have the files running in /usr/bin/
Maybe you just could help me to enter the right syntax for the
bash statement?
That' s all I need.
Thank you.
rin67630
Sun Aug 18, 2019 10:04 am
The very purpose of the thing is to have the files running in /usr/bin/ as an attempt to make this
https://github.com/deanmao/avrdude-rpi
more user friendly
bash statement?
That' s all I need.
Thank you.
PeterO
bash statement?
The right syntax is
touch fred
ln -s fred fredLink
linkname="fredLink"
if [ ! -L ${linkname} ]
then
  echo "Is a link"
fi
See https://www.tldp.org/LDP/abs/html/fto.html
PeterO
rin67630
Sun Aug 18, 2019 10:14 am
The right syntax is
Thank you Peter, but my question was not how to use the if statement, but how to specify correctly the symlink within the if statement.
I have seen that you have modified your answer. Thank you...
The original symlink was created with:
So the corresponding code would be:
linkname="/home/pi/arduino-1.8.8/hardware/tools/avr/bin/avrdude"
Correct?
PeterO
Sun Aug 18, 2019 10:17 am
You asked
Maybe you just could help me to enter the right syntax for the [command]
Try to ask the right question next time !
But you do it the same as you would specify any other file ! :shock:
PeterO
rin67630
Sun Aug 18, 2019 10:31 am
OK Peter, i'll do my best. I probably did initially with :
sudo ln ...
fi
[/code]
But then the discussion drifted and I was too lazy to re-ask the full question.
Regards.
PeterO
Sun Aug 18, 2019 10:37 am
The right syntax is
Correct?
It would be better to define a variable called avrdudeLinkName at the start of the script and set it to the full path.
Then use ${avrdudeLinkName} where ever it is needed. That way the filename only occurs in one place in the script.
DO the same for all the long pathnames.
PeterO
jahboater
Sun Aug 18, 2019 12:13 pm
This is actually a command called "test"
To see the details of the options, including -L, try
man test
Return to “Advanced users”
