skymoose
buster pi3 iscsi root partition
Mon Aug 12, 2019 2:08 pm
I have several pi2 and pi3s which I use with stretch and jessie. They have /boot on an sd and all other partitions on iscsi. This has worked really well for me. But i'm finding with buster that the same configuration is not working any longer and cannot create a / partion on iscsi with buster in the same way i used to.
I dont seem to get as far is ISCSI as the network is not appearing to start up for me...
My /boot/cmdline.txt looks like:
dwc_otg.lpm_enable=0 console=serial0,115200 console=tty1 modules=iscsi_tcp ip=192.168.0.xxx:192.168.0.yyy:192.168.0.aaa:255.255.255.0:myhost:enxb827ebde68bb:off rw rootfstype=ext4 root=UUID=b3247364-869c-47bd-986c-5968ee8c626d fsck.repair=yes cgroup_enable=cpuset cgroup_enable=memory elevator=deadline rootwait plymouth.ignore-serial-consoles panic=15
and my config.txt ends like:
enable_uart=1
initramfs initrd.img followkernel
I regenerate initrd.img and rsync the filesystems onto ISCSI storage so that they are up to date with the sd card.
Captured boot output:
...snip
[    4.192047] usb 1-1.1: new high-speed USB device number 3 using dwc_otg
[    4.332297] usb 1-1.1: New USB device found, idVendor=0424, idProduct=2514, bcdDevice= b.b3
[    4.348833] usb 1-1.1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[    4.364832] hub 1-1.1:1.0: USB hub found
[    4.376917] hub 1-1.1:1.0: 3 ports detected
[    4.702047] usb 1-1.1.2: new low-speed USB device number 4 using dwc_otg
[    4.857866] usb 1-1.1.2: New USB device found, idVendor=17ef, idProduct=6025, bcdDevice= 1.10
[    4.874551] usb 1-1.1.2: New USB device strings: Mfr=0, Product=2, SerialNumber=0
[    4.890150] usb 1-1.1.2: Product: ThinkPad USB Travel Mouse
[    4.914655] input: ThinkPad USB Travel Mouse as /devices/platform/soc/3f980000.usb/usb1/1-1/1-1.1/1-1.1.2/1-1.1.2:1.0/0003:17EF:6025.0001/input/input0
[    4.937241] hid-generic 0003:17EF:6025.0001: input,hidraw0: USB HID v11.10 Mouse [ThinkPad USB Travel Mouse] on usb-3f980000.usb-1.1.2/input0
[    5.252047] usb 1-1.1.1: new high-speed USB device number 5 using dwc_otg
[    5.392448] usb 1-1.1.1: New USB device found, idVendor=0424, idProduct=7800, bcdDevice= 3.00
[    5.409874] usb 1-1.1.1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[    5.689882] lan78xx 1-1.1.1:1.0 (unnamed net_device) (uninitialized): No External EEPROM. Setting MAC Speed
[    5.709604] libphy: lan78xx-mdiobus: probed
[    5.740605] lan78xx 1-1.1.1:1.0 (unnamed net_device) (uninitialized): int urb period 64
[   16.077723] Freeing unused kernel memory: 1024K
[   16.112406] Run /init as init process
[   16.658171] lan78xx 1-1.1.1:1.0 enxb827ebde68bb: renamed from eth0
[   61.949513] random: crng init done
[   62.656004] Kernel panic - not syncing: Attempted to kill init! exitcode=0x00000000
[   62.656004]
[   62.678724] CPU: 1 PID: 1 Comm: init Not tainted 4.19.58-v7+ #1245
[   62.691756] Hardware name: BCM2835
[   62.701905] [<80111f38>] (unwind_backtrace) from [<8010d4b0>] (show_stack+0x20/0x24)
...snip
In the output above i see the line
which is new to me. Is this potentially causing my problem here?
Any suggestions helpful please?
Return to “Advanced users”
