RichardRussell
glLogicOp(GL_OR) not working on Raspberry Pi 4?
Fri Aug 09, 2019 2:51 pm
This is a strange one. I have an application which contains the following code:
	glEnable (GL_COLOR_LOGIC_OP) ;
	glLogicOp (GL_OR) ;  // GL_AND and GL_XOR are also used
This works as expected on the RPi 3B (with the VC4 GL driver enabled) using Raspbian Jessie, Stretch or Buster. However, according to reports I have received, it is seemingly being ignored on the RPi 4 (with Buster). I haven't a clue what might be the explanation; is it possible that the OpenGL implementation on the RPi 4 is broken in respect of this functionality? It makes my application close to unusable.
PeterO
Re: glLogicOp(GL_OR) not working on Raspberry Pi 4?
Fri Aug 09, 2019 3:10 pm
Are you using openGL or openGL ES code ?
PeterO
RichardRussell
Fri Aug 09, 2019 3:37 pm
'Full' OpenGL (which is why I'm using the VC4 driver of course). OpenGL ES2 doesn't support the glLogicOp() function at all.
PeterO
Fri Aug 09, 2019 4:03 pm
Which is why I asked !
PeterO
RichardRussell
Fri Aug 09, 2019 4:09 pm
Having stated that the identical code works fine on the RPi 3, but fails on the RPi 4, I really don't think the clarification (or the question) was necessary. Do you have any suggestion as to how I can try to get this issue resolved, because I'd rather not have to tell my users to avoid the RPi 4, which has advantages in other respects (notably speed)?
trejan
Fri Aug 09, 2019 4:23 pm
https://gitlab.freedesktop.org/mesa/mes ... edc935cc74 is from a month ago but the Mesa in Raspbian is from 20190429 according to the timestamp in the version.
PeterO
Fri Aug 09, 2019 4:41 pm
The alphabet soup of abbreviations surrounding all these different drivers means I have no idea what " RPi 3B (with the VC4 GL driver enabled) " actually means (Especially as the Pi4 doesn't have a VC4!) but I do know that the logical ops have been dropped from ES, so I thought I'd ask you something that would clarify if that was the problem, but since you clearly know more about this than I do I shall now shut up.
PeterO
RichardRussell
Fri Aug 09, 2019 4:56 pm
Ah, so this is a known problem that has been fixed upstream but not yet incorporated in Raspbian? Should I be puzzled that it doesn't affect Raspbian Buster when running on the RPi 3B though? Is that Mesa version only enabled when running on a RPi 4?
Edit: Although, thinking about it, if the fix is for V3D and not VC4 perhaps that explains it.
trejan
Fri Aug 09, 2019 5:20 pm
Yeah. Different drivers inside Mesa. VC4 doesn't support logic ops either but has had a driver based implementation for a long time now. The V3D driver however didn't have support for it until that recent patch.
No idea how long you'll need to wait for a newer Mesa to appear in Raspbian.
RichardRussell
Fri Aug 09, 2019 5:42 pm
Indeed, but I guess knowing there's a fix in the pipeline is better than nothing. If anybody from the RPF is listening, at least they now know that the issue affects a popular app (BBC BASIC).
RichardRussell
Tue Aug 27, 2019 3:58 pm
To tie up loose ends, the issue is fixed in this Mesa release candidate:
https://www.raspberrypi.org/forums/view ... 6&t=249650
Return to “Advanced users”
