Ernst
How can the memory size on Pi4B be reduced ?
Thu Jun 27, 2019 9:01 am
I have been searching and I have not been able to find an answer.
What I would like to know if it possible to reduce the memory size on a Pi4B/4GB to be able to evaluate running applications on a device with 1GB or 2GB memory.
I tried to add "mem=512M" to cmdline on a Pi3B but the boot failed after this change.
procount
Re: How can the memory size on Pi4B be reduced ?
Thu Jun 27, 2019 9:09 am
NOOBS/PINN use recovery.elf, which is a copy of start_cd.elf.
This file restricts the base memory to 256MB. I assume it's use in NOOBS is to ensure it works properly on all model variants (?).
So yes, it can be done via the start.elf file, but that's closed source and probably not an option for normal users to specify the memory size.
Another thought which might be more practical for you is to create a ramdisk in tmpfs of 2GB/3GB in size to restrict the available RAM that is available.
SkyRise
Thu Jun 27, 2019 9:12 am
Or assign the extra memory to the GPU (assuming there isn't a limit here).
It then won't be available to the CPU and Linux (unless your application uses the GPU obviously...)
6by9
Thu Jun 27, 2019 10:00 am
Add "total_mem=1024" or similar to /boot/config.txt.
(docs need updating to add that one).
Ernst
Thu Jun 27, 2019 10:28 am
Thank you for this information, I just confirmed that it works using a Pi3B with Buster.
Imperf3kt
Fri Jun 28, 2019 1:06 am
A Pi3b only has 1GB of RAM anyway..
55:55:44:44:4C
52:4C:52:42:41
Ernst
Fri Jun 28, 2019 6:01 am
What can you do when the only thing you have is a Pi3B with a Pi4B/4GB in the mail ?
You can use a Pi3B and use the option to reduce the memory to 512.
This was a question about buster, not about the Pi4B, although intended for use with the Pi4B.
Imperf3kt
Fri Jun 28, 2019 10:12 am
Ah, didn't realise you wanted to reduce the memory to 512mb. Thought you wanted to reduce 1GB to 1GB
55:55:44:44:4C
52:4C:52:42:41
Return to “Advanced users”
