i am working on surveillance robot using Rpi 3 b+ need to good algorithm for self navigation
Posted: Wed May 08, 2019 7:04 am
by Abuzar
i am working on surveillance robot using Rpi 3 b+ need to good algorithm for self navigation with a particular set of coordinates from GPS module.
It supposed to do the surveillance on its own after receiving the the set of coordinates.
Please suggest me a good algorithm to do task. Thank in advance
Re: i am working on surveillance robot using Rpi 3 b+ need to good algorithm for self navigation
Posted: Sun May 12, 2019 2:19 am
by Joel_Mckay
Have a look at ROS or MRPT.
You will need to be more specific about the platform, as guidance and navigation are separate classes of problems.
Cheers.
J
Posted: Sun May 12, 2019 2:53 am
by LTolledo
Do you "need":
1. a guide to make the the algorithm?
2. a full running algorithm ( as in served in a silver platter)?
Posted: Sun May 12, 2019 3:00 am
by PhatFil
kiss when forward path is obscured turn right.
Posted: Sun May 12, 2019 3:56 am
by ElEscalador
Look up A*? Or go with ROS and try gmapping or hector...not really enough info and likely gps alone will not be adequate. There is so much error in sensors that typically a bunch are used and the data fused and vetted. indoor? Outdoor?
Posted: Sat May 18, 2019 10:54 am
by LTolledo
.... topic on watch list.... possible spam-bot generated content....
