gdouglas
High percentage of Ethernet Failures - Pi 3B
Fri Apr 05, 2019 4:51 pm
I'm beginning to wonder if there's a serious issue with the Ethernet part on the 3B.
I have 8 - 3B units and of those 8, 3 of them have experienced Ethernet hardware failure. All are relatively new units (<1 year old). One died the day I received it.
While the kernel still sees the part -- and the drivers load, Ethernet link and communication always fails -- and in fact the Link LED on the pi illuminates regardless of the presence of a cable or link partner. Eth0 comes up and gets an avahi autoconf IP address.
Yes -- I've tried different OS images (I'm using the latest Raspian lite in general), cables, switches, config tweaks etc, and even hard locking switch ports to all of the various speed/duplex combinations. The symptom is always the same.
I'm looking to understand why this is happening in such high number. The USB ports all still work just fine.
Is there a process by which I can send these units back for analysis -- and/or is there any documentation regarding how or why the part (and I suspect specifically the Ethernet PHY's analog side) might fail?
Is there a known design problem / errata that might explain my experience?
Thanks in advance!
pcmanbob
Re: High percentage of Ethernet Failures - Pi 3B
Fri Apr 05, 2019 6:07 pm
Hi.
I think if this was a common issue then with the millions of pi3B's that have been sold we would have seen a lot of people coming to the forum for help and a lot of suppliers complaining due to the number of returns.
First I would look at the network you are connecting them to ( assuming they are all connected to one network ) to see if there is something like a bad switch or a switch with poe turned on, that could be causing these failures.
gdouglas
Fri Apr 05, 2019 7:54 pm
I agree with your response -- but i've 'been there done that' with cables etc!
Everything's been checked -- and in fact I quarantined my original switch just in case -- and changed over to another but it still happens.
FYI: in addition to the units I have, a partner has another, larger number of pi 3B's (out of an order of about 100pcs) that exhibit the same symptoms. Completely different network.
FYI2: Our process is:
1) Enable USB boot on the pi with a stripped down image (Sadly the 3B doesn't come with USB boot enabled)
2) Netboot the pi with a blank SD card
3) Have the pi image itself (using dd) from an imaged stored on NFS.
The units usually break between 1 and 2.
I'm mostly looking for guidance on what, from a hardware perspective, could kill the Phy in such a manner -- and could this somehow be a side-effect of enabling network booting/power/etc.
mahjongg
Sat Apr 06, 2019 12:24 pm
copy sent to moderators.
dobova86
Sun Apr 07, 2019 8:18 am
I read somewhere, that microchip lan951x chip production has changed recently for some weakness in the industrial model due to temperature. I can’t remind where I got the news, but this was not related to Pi.
gdouglas
Mon Apr 08, 2019 4:42 pm
Thanks for the lan951x info. I'll look into errata. All help is greatly appreciated.
Tue Apr 09, 2019 10:10 am
Hi gdouglas,
we would be interested in getting one or two of your defective boards back for testing, as this is not a problem we have seen before.
Can you send an email to info@raspberrypi.org, FAO JamesH, and we can organise something over email rather than on here.
James
“I own the world’s worst thesaurus. Not only is it awful, it’s awful."
gdouglas
Mon Apr 15, 2019 2:58 pm
Thanks JamesH -- email sent.
Mon Apr 15, 2019 7:45 pm
I've got a few days off over Easter, so don't expect a reply until next week!
gdouglas
Wed Apr 17, 2019 3:36 pm
Thanks for letting me know -- and enjoy your time off.
Reply when you can. I have devices ready to send.
gdouglas
Tue Apr 30, 2019 4:07 pm
Hi James -- hope you had a good Easter break!
I haven't seen a reply from you via email. I re-sent a message this morning.
Thanks.
Tue Apr 30, 2019 8:36 pm
Thanks.
Hmm, nothing made it to me first go , I'll see what happens with the one this morning. Make sure you address it FAO James Hughes
gdouglas
Fri May 03, 2019 5:54 pm
Hi again James -- I sent the emails again ( a couple of different ways) to info@raspberrypi.org -- did you receive them?
Is there some other way we can connect?
Thanks~!
BespokeTech
Thu May 09, 2019 3:59 pm
Thanks in advance!
Any PoE come into play here? I note you mention that you have tried different switches cables etc, but presumably that was after each one had died! Did the 3 faulty pi's all die when plugged into the same switch hardware? If so I would be interested to know the make/model of network switch used.
Thu May 09, 2019 4:01 pm
Thanks~!
info@ is the appropratie way, I'll ask around to see what's happened to them.
Return to “Advanced users”
