I can't boot my raspberry 3 on a hard drive on usb. I tried with 4 different hard drives.
However, with my usb keys, it works well. For information, I don't insert any card sd.
Can you help me?
Thank you in advance!
Not all HDDs are compatible.
So either your HDD is not compatible or you did not set it up correctly.
Without any more details about your setup it's not possible to say more
What type of HDD exactly did you try? How are they powered?
I'm only working on my ssd usb with its 700mA.
In fact, it's still the same problem, it starts well a first time, I can work on it without problem but impossible to restart it after a reboot or a stop ... I have to put raspbian on the ssd to restart the raspberry
Has anyone come across this problem before???
Thank you!
