David Ryan
No reboot switching between client/AP mode?
Tue Dec 18, 2018 6:03 pm
I would like to be able to switch from client mode to AP and then back again without rebooting.
I followed these instructions on how to set up AP mode. And I do the inverse to get back, but for the settings to take effect I need to reboot. After I run the commands listed below I can successfully disable the mode I'm in, but I can't get the new settings to work until I reboot. I'm assuming there's some service I need to enable/disable, but I'm not sure which. Any help would be greatly appreciated.
Some additional info. I have been able to get the AP broadcasting without reboot but the ifconfig results still show a connection to my outside network.
After changing the files I've tried.
Client to AP
daemon-reload
restart dhcpcd
restart dnsmasq
start hostapd
re-run rc.local masquerade
run sysctl -p
AP to client
the same only stopping hostapd and running wpa_cli reconfigure
Abdul Wajid
Re: No reboot switching between client/AP mode?
Sat Jan 26, 2019 6:13 am
Mr. David,
I have read your post and I notice that the same thing that i want now is related to your post. Most possibly you have the solution to it or you can help me in it.
Picture of my question attached below and link is also given
https://www.raspberrypi.org/forums/view ... 4#p1420695
Thanks in advance,
Abdul Wajid,
Return to “Advanced users”
