christosf360
Error capturing video from the Pi camera with Open CV
Sun Dec 09, 2018 8:51 pm
Hello everyone,
I am using my Pi to experiment with a little project and I am trying to capture video via the Pi camera (to begin with). On the OpenCV website I found this very simple piece of code but unfortunately when I run it it produces an error (The error begins with "Assertion failed". Any suggestions please?
Here is the code:
import numpy as np
import cv2
cap = cv2.VideoCapture(0)
while(True):
    # Capture frame-by-frame
    ret, frame = cap.read()
    # convert in gray
    gray = cv2.cvtColor(frame, cv2.COLOR_BGR2GRAY)
    # Display the resulting frame
    cv2.imshow('frame',gray)
    if cv2.waitKey(1) & 0xFF == ord('q'):
        break
# When everything done, release the capture
cap.release()
cv2.destroyAllWindows()
DirkS
Re: Error capturing video from the Pi camera with Open CV
Sun Dec 09, 2018 8:58 pm
Please post the *full* error message
christosf360
Sun Dec 09, 2018 9:36 pm
Apologies, the error says:
OpenCV Error: Assertion failed (size.width>0 && size.height>0) in imshow, file /build/opencv-ISmtkH/opencv-2.4.9.1+dfsg/modules/highgui/src/window.cpp, line 269
File "myversion_1.py", line 31, in <module>
cv2.imshow("Frame", frame)
cv2.error: /build/opencv-ISmtkH/opencv-2.4.9.1+dfsg/modules/highgui/src/window.cpp:269: error: (-215) size.width>0 && size.height>0 in function imshow
DirkS
Sun Dec 09, 2018 9:54 pm
I googled the error and it basically means there's no image (width and or height is zero)
So you will have to do a step back and get your input working.
christosf360
Sun Dec 09, 2018 10:24 pm
OK, thank you, I will have a look.
However, I thought that these lines, provide the images:
while(True):
il_diavolo
Mon Dec 10, 2018 10:27 pm
I will be interested to see if you solve this.
I have had the Pi camera working with OpenCV for a couple of years, first with Jessie and then with Stretch but after a recent apt-get update and upgrade the code (very similar to yours) ceased to work. I have had to rewrite using Picamera instead of OpenCV to read the video stream. My second camera, a USB web cam, continues to work with OpenCV.
il_diavolo
Tue Dec 11, 2018 10:23 pm
I should have asked in yesterday's post, did you start the v4l2 driver?
Type "sudo modprobe bcm2835-v4l2" in a terminal window before you run the program.
christosf360
Wed Dec 12, 2018 5:30 pm
I am going to try these drivers and let you know
Return to “Python”
