hawkesley
Help with Flask
Wed Dec 05, 2018 4:24 pm
I am trying to get a grip of Flask for a project.
I would like to call a python script from a Flask web page which plays a text file using espeak.
I have the following which works, but it only works once when the page is rendered, not if I refresh the page.
I think I am missing a basic concept of how this should be structured.
Any help or tutorials welcome.
My files so far:-
app.py - imports Audio.py
from flask import Flask, render_template
app = Flask(__name__)
walks = [
        'walk': 'Tintagel',
        'desciption': 'TBA'
        'walk': 'Bude',
        'desciption': 'TBA'
@app.route('/')
def index():
    import Audio
    return render_template('index.html', walks=walks)
@app.route('/showmap')
def showmap():
    import Audio
    return render_template('showmap.html', title='Show Map')
@app.route('/hello/<name>')
def hello(name):
    return render_template('page.html', name=name)
if __name__ == '__main__':
    app.run(debug=True, host='0.0.0.0')
Audio.py
from subprocess import call
file = open('Audio.txt','r')
text = file.read().strip()
file.close
speech= text
call(["espeak",speech])
Andyroo
Re: Help with Flask
Wed Dec 05, 2018 4:35 pm
I'm learning both but I think the issue is in the audio.py in that the speech command is only called when the module is imported - i.e. it treat as set-up code.
You need to create a function and call that from the page not import it (as that happens once only).
audio.py
def speaktext():
    file.close
    speech= text
# Put any set up code you need below this line
then the page code becomes:
import audio.py
walks = [
        'walk': 'Tintagel',
        'desciption': 'TBA'
        'walk': 'Bude',
        'desciption': 'TBA'
@app.route('/')
def index():
    speaktext()
def showmap():
    import Audio
def hello(name):
Then when you refresh the index page it should speak each time.
This is untested (my Pi is a bit in bits today)... You with care and caution.
scotty101
Re: Help with Flask
Wed Dec 05, 2018 4:36 pm
You'll need modify the Audio.py file so that it contains a function that can be called from the flask script. An import will only occur once.
Audio.py
def speakFile():
    with open('Audio.txt','r') as file:
    call(["espeak",text])
Then in the flask python file you would do something like this
#import the function at the start! Not later
from Audio import speakFile
def showmap():
    speakFile()
EDIT: Snap!!! Good to see that two people came up with almost identical solutions. Andyroo, no need to have the .py file extension when you import python modules "import Audio" will do.
file.close
should be
file.close()
but it is better to do what I've done above and use the "with" context manager to automatically close the file once it has been used.
Andyroo
Re: Help with Flask
Wed Dec 05, 2018 4:59 pm
@scotty101
Thanks for those corrections :)
Putting the file extension dates back to my Pascal days. Though I had a case on Monday where a program would not run without it (nano edited / cmd line executed) but not got to the bottom of why yet.
I did not know about the 'with' - thanks for that tip.
hawkesley
Re: Help with Flask
Thu Dec 06, 2018 4:45 pm
Thanks Guys I will try that and let you know
hawkesley
Re: Help with Flask
Fri Dec 07, 2018 2:16 pm
I have updated the files and tested the following which works.
However if I enclose file.close I get a syntax error.
Also the current file plays the Audio before rendering the page so how do I play the Audio after the template has rendered , perhaps with a selection button?
Any help appreciated.
Audio.py
def speakFile
//including file.close here causes syntax error
app.py
import Audio
walks = [
        'walk': 'Tintagel',
        'desciption': 'TBA'
        'walk': 'Bude',
        'desciption': 'TBA'
@app.route('/')
def index():
def showmap():
    speakFile
def hello(name):
scotty101
Re: Help with Flask
Fri Dec 07, 2018 3:33 pm
I'll repeat what I said above.
file.close
should be
file.close()
Also
speakFile
Should be
speakFile()
Flask/Python is the server. Your webbrowser renders the webpage. The code currently plays the audio before the server sends the response back to the browser.
You could theoretically have the flask request function schedule the sound to be played after a delay but you can't (easily) sync the playing with the webpage being rendered.
Another method is that you modify the HTML so that the browser plays the audio rather than flask.
hawkesley
Re: Help with Flask
Fri Dec 07, 2018 4:08 pm
Thanks for the corrections and advice.
Return to “Advanced users”
