Black Sreen with blinking pointer and root@(none):/#
Posted: Tue Dec 04, 2018 11:07 am
by gerypending
Hi!
I'm currently working on a robotic project, my robot uses a TFT LCD screen as eyes and when I was following the datasheet from the supplier to set up the LCD screen I don't know what happened but now a black screen appears after reboot the system and I can't access to my system.
I attached the link from the datasheet, the files I added and I will want to remove are the one from the point 2.3 of the datasheet :
http://anleitung.joy-it.net/wp-content/ ... Manual.pdf
Searching on different forums I could access to the system but all was in only read mode so I couldn't remove the files I added during the set up of the LCD screen and now appears the following lines:
bash: cannit set terminal process group (-1): Inappropriate ioctl for device
bash: no job control in this shell
root@(none):/#
I tried to fix it but I'm not an advanced user of raspberry and I don't know what more to do.
If someone knows how to repair it please help me as soon as possible!
Thanks in advance :D
