dbasberg
Check for crashed program periodically?
Sun Nov 18, 2018 7:46 pm
I use one of my PIs to control a solar power system. It needs to be running always. The Modbus connection is run with a less than perfect library routine. It can crash periodically. I would like to test periodically for the program executing and restart it if not executing. Perhaps I can use 'crontab' to do this. I am not very Linux or shell competent and wonder how I can test for my program executing periodically and then restarting if necessary. Any help with this is greatly appreciated. This is key to my handling of critical programs. :?:
Five RPIs: 2:256 & 2:512 and an RPI3 used for monitor and control in out buildings of farm (embedded controls). Linux/Python novice. Experienced real-time programmer/hardware/systems designer (asm, C, C++).
Andyroo
Re: Check for crashed program periodically?
Sun Nov 18, 2018 8:36 pm
Not sure if I would get cause more outrage for saying fix your program or do not use the Pi for mission critical devices so i’ll avoid them like the plague :mrgreen: and say for you to have a look at watchdog timers..
This series of articles https://www.switchdoc.com/2017/08/relia ... -arduinos/ is a good coverage of this process as a place to start.
Sun Nov 18, 2018 9:07 pm
It might be worth a look at the supervisor package. It's a program that will start other programs for you and restart them if they fail. I think it's written in Python.
rzusman
Sun Nov 18, 2018 9:34 pm
You can create a system service that will re-launch a crashed process automatically.
https://medium.com/@benmorel/creating-a ... 1b5c8b91d6
This won’t fix a hung process - you need a watchdog for that.
dbasberg
Mon Nov 19, 2018 1:36 am
The library I use for serial modbus is not mine. I do not see where to fix it.
The advise you three have given me has set me to learning. I think my answer is in there somewhere.
Thanks for the help.
It is up to me to learn now. :D
dbasberg
Mon Nov 19, 2018 5:47 pm
I am exploring this for more than this current problem. It looks like a powerful approach for other things I do regularly. My thanks to you for taking the time to point me in this direction. 8-)
Return to “Advanced users”
