Page 1 of 12
Moving Linux kernel to 4.19 [Already moved for many months now (in january 2020)]
Posted: Tue Oct 16, 2018 7:45 pm
by dom
We are planning to move to the 4.19 kernel in the near future (perhaps a few months).
One advantage is there is more raspberry pi specific support in the newer upstream kernels which reduces the number of downstream raspberry pi patches and so reduces maintenance effort.
The 4.19 kernel is planned to be an LTS kernel (long term support).
Obviously a newer kernel will bring additional kernel features and support for more devices (e.g. USB devices like wifi and dvb).
You can read up on what appeared in 4.15, 4.16 ,4.17, 4.18 and 4.19.
We will do this in a few stages. Starting now, we are updating the "next" firmware branch to the 4.18 kernel.
When the 4.19 kernel leaves release candidate stage we'll switch to 4.19. (Currently on rc8 so should be soon).
Assuming testing is positive, we'll update the master rpi-update firmware branch.
Eventually the 4.19 kernel will appear with "apt upgrade" and on new raspbian images in the future.
The 4.18 kernel has been used in LibreELEC nightly builds for a while (and there are weekly test build of the release candidate version of 4.19).
Update with:
sudo rpi-update
and reboot. Ideally nothing much will change.
Please report if there are any regressions compared to the 4.14 kernel.
Obviously this release is for testers who like to live on the bleeding edge. It's not intended for beginners, or users who need stability.
Backing up is always advisable. There may be regressions. There may be improvements. But we won't know without testers trying it and reporting back.
EDIT: we are now on the 4.19 tree as upstream kernel has left release candidate stage.
EDIT2: we have now updated master branch of rpi-update to the 4.19 kernel
EDIT3: we now have 4.19 kernel as default from apt.
Re: Moving Linux kernel to 4.19
Posted: Tue Oct 16, 2018 8:52 pm
by cjan
since raspbian blacklist rtl8192cu module by default, so use 8192cu and all good.
with 4.18, 8192cu loaded but don't connect anymore.
ps. Edimax EW-7811Un
Posted: Tue Oct 16, 2018 9:17 pm
by dom
To confirm, you have been using the out of tree 8192cu driver on 4.14 (with rtl8192cu blacklisted), but this isn't working on 4.18?
What happens if you blacklist 8192cu and try using the upstream driver? Does that work for you?
(There may have been improvements to upstream driver since 4.14).
Posted: Tue Oct 16, 2018 9:45 pm
by cjan
yes, rtl8192cu work with both 4.14 & 4.18.
but didn't like it, cause led indicator not blink, want 8192cu back.
Posted: Tue Oct 16, 2018 11:25 pm
by MrEngman
Updated the clone of Linux source to include the new kernel source 4.18.14+ to check and update the wifi drivers I compile to run on kernel 4.18.
However, I am unable to configure the kernel so I can compile the drivers as make modules_prepare fails with an error I'm having problems fixing. Initially had issues re bison and flex but installing bison and flex sorted those and the kernel configuration now runs but terminates with an error.
I'm configuring the kernel using commands
make mrproper
make bcmrpi_defconfig
make modules prepare
for armv6 and
make mrproper
make bcm2709_defconfig
for armv7.
make modules_prepare initially gets a warning
  CC      arch/arm/kernel/asm-offsets.s
  UPD     include/generated/asm-offsets.h
  CALL    scripts/checksyscalls.sh
<stdin>:1332:2: warning: #warning syscall io_pgetevents not implemented [-Wcpp]
  HOSTCC  scripts/dtc/dtc.o
  HOSTCC  scripts/dtc/flattree.o
  HOSTCC  scripts/dtc/fstree.o
but then the compile fails with this error
  HOSTCC  scripts/sortextable
  HOSTCC  scripts/asn1_compiler
  HOSTCC  scripts/extract-cert
scripts/extract-cert.c:21:25: fatal error: openssl/bio.h: No such file or directory
 #include <openssl/bio.h>
compilation terminated.
scripts/Makefile.host:90: recipe for target 'scripts/extract-cert' failed
make[1]: *** [scripts/extract-cert] Error 1
Makefile:1062: recipe for target 'scripts' failed
make: *** [scripts] Error 2
Checking the linux source there is no file openssl/bio.h, no directory openssl, but there is a file include/linux/bio.h
The file scripts/extract-cert.c includes several references to files in directory openssl but this directory does not exist. e.g.
#define _GNU_SOURCE
#include <stdio.h>
#include <stdlib.h>
#include <stdint.h>
#include <stdbool.h>
#include <string.h>
#include <err.h>
#include <openssl/pem.h>
#include <openssl/err.h>
#include <openssl/engine.h>
Am I missing something or is it that the openssl directory is missing from the kernel source.
Don't know if it is relevant but I'm compiling on a Pi 3B+ with kernel Stretch 4.14.76-v7+ (raspbian-lite)
Posted: Wed Oct 17, 2018 12:58 am
by asavah
apt install libssl-dev
Posted: Wed Oct 17, 2018 10:14 am
by MrEngman
Thanks asavah,
That fixed the issue with openssl/bio.h.
Posted: Thu Oct 18, 2018 7:02 pm
by dom
Can you update and try 8192cu again? I've pulled in a few patches that could help.
Posted: Thu Oct 18, 2018 9:28 pm
by MrEngman
Similar issue here. Updated Pi to 4.18.14+ #1151 and 8192cu loaded but no wifi connection. However, updated to the latest raspberrypi/firmware/next, 4.18.14+ #1153, and 8192cu now appears to be working with Edimax EW-7811Un. At least I now have a wifi connection again.
Posted: Thu Oct 18, 2018 11:22 pm
by ejolson
Nice to see the Pi is keeping up to date with latest kernel developments. For me the latest kernel is important for BTRFS.
Between the 4.9.x series and the 4.14.x series there was a regression that prevented the USB Ethernet Gadget from using jumbo packets. More information is in this thread and confirmed here and further analyzed later in the same thread. As a result, I'm currently stuck with 4.9.x series on this Pi Zero cluster.
If this regression is already fixed upstream that's great, otherwise, if there is anyway to fix this regression downstream for the 4.19.x kernels used for Raspbian that would be wonderful.
Posted: Fri Oct 19, 2018 1:14 am
by cjan
back to 8192cu, traffic led blink blink, thanks.
Posted: Fri Oct 19, 2018 5:48 am
by PhilE
Opening an issue in our GitHub Linux repo is the best way to report regressions like this.
Posted: Fri Oct 19, 2018 4:37 pm
by ejolson
I see the list of open problems but no way to add anything. How do I do that?
Posted: Fri Oct 19, 2018 4:38 pm
by PhilE
Click on the green button labelled "New issue".
Posted: Fri Oct 19, 2018 5:21 pm
by ejolson
It was a not green + sign on the mobile site and then the submit button was placed invisibly under the text entry form because font size was too big. Issue is submitted now. Thanks!
Posted: Sun Oct 21, 2018 9:55 am
by DougieLawson
With 4.18.14-v7+ my Google AIY HAT isn't working on my 3B+
[    8.072630] voicehat-codec voicehat-codec: property 'voicehat_sdmode_delay' not found default 5 mS
[    8.105174] snd-rpi-simple soc:sound: Unable to allocate GPIO pin
[    8.105194] voicehat-codec voicehat-codec: ASoC: failed to probe component -2
[    8.105244] snd-rpi-simple soc:sound: ASoC: failed to instantiate card -2
[    8.105362] snd-rpi-simple soc:sound: Failed to register card -2
[    8.105396] snd-rpi-simple: probe of soc:sound failed with error -2
I'll give it a reboot and look for those messages again. If it still doesn't work I'll take that one back to 4.14.77-v7+.
Posted: Sun Oct 21, 2018 11:35 am
by PhilE
@Dougie Add "dtdebug=1" to your config.txt, reboot, then post the output of:
$ sudo vcdbg log msg |& grep -iv hdmi
Posted: Sun Oct 21, 2018 2:49 pm
by DougieLawson
010478.826: brfs: File read: /mfs/sd/config.txt
010481.610: brfs: File read: 3177 bytes
011192.549: brfs: File read: /mfs/sd/config.txt
011416.128: gpioman: gpioman_get_pin_num: pin DISPLAY_DSI_PORT not defined
011517.317: *** Restart logging
011517.393: brfs: File read: 3177 bytes
011964.031: brfs: File read: /mfs/sd/cmdline.txt
011964.139: Read command line from file 'cmdline.txt':
011964.206: 'dwc_otg.lpm_enable=0 console=serial0,115200 console=tty1 root=PARTUUID=86c71275-02 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait quiet splash plymouth.ignore-serial-consoles'
011964.536: brfs: File read: 187 bytes
018116.861: brfs: File read: /mfs/sd/kernel7.img
018116.927: Loading 'kernel7.img' to 0x8000 size 0x4fb038
018131.998: No kernel trailer - assuming DT-capable
018132.071: Trying Device Tree file 'bcm2710-rpi-3-b-plus.dtb'
018132.139: brfs: File read: 5222456 bytes
018480.924: brfs: File read: /mfs/sd/bcm2710-rpi-3-b-plus.dtb
018480.993: Loading 'bcm2710-rpi-3-b-plus.dtb' to 0x503038 size 0x5fb7
018498.378: dtdebug: delete_node(/__local_fixups__)
018508.094: dtdebug: /aliases:i2c_vc=i2c0
018517.803: dtdebug: /__symbols__:i2c_vc=i2c0
018525.136: dtdebug: /__overrides__:i2c_vc=i2c0
018539.131: dtdebug: /__overrides__:i2c_vc_baudrate=i2c0_baudrate
018543.557: dtdebug: /aliases:i2c=i2c1
018553.433: dtdebug: /__symbols__:i2c=i2c1
018560.842: dtdebug: /__overrides__:i2c=i2c1
018565.298: dtdebug: /aliases:i2c_arm=i2c1
018575.259: dtdebug: /__symbols__:i2c_arm=i2c1
018582.687: dtdebug: /__overrides__:i2c_arm=i2c1
018596.927: dtdebug: /__overrides__:i2c_baudrate=i2c1_baudrate
018611.139: dtdebug: /__overrides__:i2c_arm_baudrate=i2c1_baudrate
018617.966: dtparam: uart0_clkrate=48000000
018623.368: dtdebug: /__overrides__ has no uart0_clkrate property
018623.382: Unknown dtparam 'uart0_clkrate' - ignored
018623.448: brfs: File read: 24503 bytes
018879.342: brfs: File read: /mfs/sd/config.txt
018880.176: dterror: not a valid FDT - err -9
018880.188: Failed to load HAT overlay
018880.255: brfs: File read: 3177 bytes
019292.423: dtdebug: Opened overlay file 'overlays/googlevoicehat-soundcard.dtbo'
019332.286: brfs: File read: /mfs/sd/overlays/googlevoicehat-soundcard.dtbo
019350.648: Loaded overlay 'googlevoicehat-soundcard'
019350.721: dtparam: i2s=on
019351.048: dtdebug: /__overrides__ node not found
019356.171: dtdebug: Found override i2s
019356.207: dtdebug:   override i2s: string target 'status'
019365.147: dtdebug: Found fragment 0 (offset 36)
019375.822: dtdebug: merge_fragment(/soc/i2s@7e203000,/fragment@0/__overlay__)
019375.848: dtdebug:   +prop(status)
019377.912: dtdebug: merge_fragment() end
019377.970: dtdebug: Found fragment 1 (offset 112)
019381.053: dtdebug: merge_fragment(/soc/gpio@7e200000,/fragment@1/__overlay__)
019388.566: dtdebug: merge_fragment(/soc/gpio@7e200000/googlevoicehat_pins,/fragment@1/__overlay__/googlevoicehat_pins)
019388.598: dtdebug:   +prop(brcm,pins)
019391.334: dtdebug:   +prop(brcm,function)
019394.087: dtdebug:   +prop(brcm,pull)
019396.859: dtdebug:   +prop(phandle)
019399.584: dtdebug: merge_fragment() end
019399.618: dtdebug: merge_fragment() end
019399.700: dtdebug: Found fragment 2 (offset 260)
019399.918: dtdebug: merge_fragment(/,/fragment@2/__overlay__)
019414.066: dtdebug: merge_fragment(/voicehat-codec,/fragment@2/__overlay__/voicehat-codec)
019414.096: dtdebug:   +prop(#sound-dai-cells)
019417.197: dtdebug:   +prop(compatible)
019420.118: dtdebug:   +prop(pinctrl-names)
019423.209: dtdebug:   +prop(pinctrl-0)
019426.328: dtdebug:   +prop(sdmode-gpios)
019429.944: dtdebug:   +prop(status)
019433.104: dtdebug: merge_fragment() end
019433.139: dtdebug: merge_fragment() end
019433.222: dtdebug: Found fragment 3 (offset 464)
019452.168: dtdebug: merge_fragment(/soc/sound,/fragment@3/__overlay__)
019452.195: dtdebug:   +prop(compatible)
019453.437: dtdebug:   +prop(i2s-controller)
019455.350: dtdebug:   +prop(status)
019456.607: dtdebug: merge_fragment() end
019456.795: brfs: File read: 1259 bytes
019934.268: dtdebug: Failed to open overlay file 'overlays/i2s-mmap.dtbo'
020502.346: dtdebug: Failed to open overlay file 'overlays/i2s-mmap-overlay.dtb'
021070.298: dtdebug: Failed to open overlay file 'overlays/i2s-mmap.dtb'
021070.311: Failed to load overlay 'i2s-mmap'
021071.072: dtparam: spi=on
021076.294: dtdebug: Found override spi
021076.330: dtdebug:   override spi: string target 'status'
021085.785: dtparam: i2c_arm=on
021090.978: dtdebug: Found override i2c_arm
021091.015: dtdebug:   override i2c_arm: string target 'status'
021114.224: dtparam: uart1=off
021119.455: dtdebug: Found override uart1
021119.492: dtdebug:   override uart1: string target 'status'
022297.247: dtparam: cam0-pwdn-ctrl=28
022302.836: dtdebug: /__overrides__ has no cam0-pwdn-ctrl property
022302.852: Unknown dtparam 'cam0-pwdn-ctrl' - ignored
022302.916: dtparam: cam0-pwdn=5
022308.510: dtdebug: /__overrides__ has no cam0-pwdn property
022308.524: Unknown dtparam 'cam0-pwdn' - ignored
022320.144: dtparam: cam0-led-ctrl=28
022325.760: dtdebug: /__overrides__ has no cam0-led-ctrl property
022325.774: Unknown dtparam 'cam0-led-ctrl' - ignored
022325.838: dtparam: cam0-led=6
022331.434: dtdebug: /__overrides__ has no cam0-led property
022331.448: Unknown dtparam 'cam0-led' - ignored
022331.514: gpioman: gpioman_get_pin_num: pin EMMC_ENABLE not defined
022331.604: dtparam: arm_freq=1400000000
022337.060: dtdebug: Found override arm_freq
022337.110: dtdebug:   override arm_freq: cell target clock-frequency @ offset 0 (size 4)
022352.083: dtdebug:   override arm_freq: cell target clock-frequency @ offset 0 (size 4)
022367.217: dtdebug:   override arm_freq: cell target clock-frequency @ offset 0 (size 4)
022382.377: dtdebug:   override arm_freq: cell target clock-frequency @ offset 0 (size 4)
022397.629: dtparam: core_freq=400000000
022403.244: dtdebug: /__overrides__ has no core_freq property
022403.256: Unknown dtparam 'core_freq' - ignored
022415.719: dtdebug: delete_node(/hat)
022460.246: Device tree loaded to 0x2eff9900 (size 0x6631)
024872.861: vchiq_core: vchiq_init_state: slot_zero = 0xf7880000, is_master = 1
024882.679: TV service:host side not connected, dropping notification 0x00000002, 0x00000002, 0x00000051
Posted: Sun Oct 21, 2018 3:07 pm
by PhilE
Here's the problem:
The HAT EEPROM is corrupt or not programmed. Try with "dtoverlay=googlevoicehat-soundcard" instead.
Posted: Sun Oct 21, 2018 3:18 pm
by DougieLawson
That's already in my "unified" /boot/config.txt - I use the same config on all of my Raspberries.
# Unified config.txt @ 28/09/2018 21:43
[0xe685c936]
# ** Apollo     : e685c936 **
# ** Raspberry Pi Model B Plus Rev 1.2
dtparam=audio=on
dtoverlay=i2c-rtc,ds1307
max_usb_current=1
gpu_mem=16
initramfs initrd.sda followkernel
hdmi_force_hotplug=1
hdmi_group=2
hdmi_mode=81
[0x7fbb0a6c]
# ** Beaufort   : 7fbb0a6c **
# ** Raspberry Pi 2 Model B Rev 1.1
dtparam=audio=on
dtoverlay=w1-gpio
dtoverlay=i2c-rtc,pcf8523
dtoverlay=i2c-sensor,bmp180
dtoverlay=i2c-sensor,htu21
max_usb_current=1
hdmi_group=2
hdmi_mode=81
[0x8e8dd26c]
# ** Challenger : 8e8dd26c **
# ** Raspberry Pi 3 Model B Rev 1.2
dtparam=audio=on
#start_x=1
lcd_rotate=2
[0x5a67d427]
# ** Eagle      : 5a67d427 **
dtparam=audio=on
max_usb_current=1
hdmi_group=2
hdmi_mode=81
[0x18ae9924]
# ** Endeavour  : 18ae9924 **
dtparam=audio=on
hdmi_group=1
hdmi_mode=16
[0xebd5f1e8]
# ** Falcon     : ebd5f1e8 **
# ** Raspberry Pi Zero Rev 1.2
dtparam=audio=on
gpu_mem=64
dtparam=act_led_activelow=on
enable_uart=1
#dtoverlay=enc28j60,int_pin=25,speed=20000000
#disable_audio_dither=1
#hdmi_force_hotplug=1
#hdmi_group=1
#hdmi_mode=16
[0x3d5fffed]
# ** Gemini     : 3d5fffed **
# ** Raspberry Pi Model B Rev 2
dtparam=audio=on
hdmi_group=2
hdmi_mode=81
[0x3f3cd8c4]
# ** Hitchhiker : 3f3cd8c4 **
# ** Raspberry Pi 3 Model B Plus Rev 1.3
dtparam=i2s=on
dtoverlay=i2s-mmap
start_x=1
gpu_mem=128
hdmi_group=2
hdmi_mode=81
[0xed1519f1]
# ** Intrepid   : ed1519f1 **
dtparam=audio=on
hdmi_group=2
hdmi_mode=81
dtoverlay=rpi-tv
[0xaf84e8d0]
# ** Mercury    : af84e8d0 **
# ** Raspberry Pi Zero W Rev 1.1
dtparam=audio=on
hdmi_group=1
hdmi_mode=31
[0xc2355259]
# ** Odyssey    : c2355259 **
dtparam=audio=on
dtoverlay=lirc-rpi,gpio_in_pin=23,gpio_in_pull=high
gpu_mem=128
start_x=1
disable_camera_led=1
hdmi_group=2
hdmi_mode=81
[0x4800069e]
# ** Pioneer    : 4800069e **
dtparam=audio=on
hdmi_group=1
hdmi_mode=16
[0x9b930691]
# ** Ranger     : 9b930691 **
dtparam=audio=on
dtoverlay=rpi-cirrus-wm5102
dtoverlay=i2s-mmap
hdmi_group=1
hdmi_mode=16
[0x62144670]
# ** Saturn     : 62144670 **
dtparam=audio=on
hdmi_group=1
hdmi_mode=16
[0x5b592f7f]
# ** Viking     : 5b592f7f **
# ** Raspberry Pi Model A Plus Rev 1.1
dtparam=audio=on
gpu_mem=16
hdmi_group=2
hdmi_mode=81
[all]
dtparam=spi=on
dtparam=i2c_arm=on
disable_splash=1
dtdebug=1
The 3B+ with the AIY HAT is 0x3f3cd8c4 (machine is Hitchhiker).
Posted: Sun Oct 21, 2018 3:52 pm
by PhilE
The driver treats the GPIO allocation failure as a fatal error. The Voice HAT only uses a single GPIO - GPIO 16 - and I can't think what else would be using it, but you can probably find out with:
$ raspi-gpio get 16
$ sudo grep 16 /sys/kernel/debug/pinctrl/3f200000.gpio/{pinmux-,}pins
Posted: Sun Oct 21, 2018 4:00 pm
by DougieLawson
This is what I get on 4.14.77-v7+.
root@hitchhiker:~ # raspi-gpio get 16
GPIO 16: level=1 fsel=1 func=OUTPUT
root@hitchhiker:~ # grep 16 /sys/kernel/debug/pinctrl/3f200000.gpio/{pinmux-,}pins
/sys/kernel/debug/pinctrl/3f200000.gpio/pinmux-pins:pin 16 (gpio16): voicehat-codec pinctrl-bcm2835:16 function gpio_out group gpio16
/sys/kernel/debug/pinctrl/3f200000.gpio/pins:pin 16 (gpio16) function gpio_out in hi; irq 0 (none)
root@hitchhiker:~ #
I'll go back to 4.18.14-v7+, watch this space.
GPIO 16: level=0 fsel=1 func=OUTPUT
grep: /sys/kernel/debug/pinctrl/3f200000.gpio/pinmux-pins: No such file or directory
grep: /sys/kernel/debug/pinctrl/3f200000.gpio/pins: No such file or directory
root@hitchhiker:~ #
Posted: Sun Oct 21, 2018 4:07 pm
by PhilE
When we first started using Device Tree for pin configuration we found an oddity - that GPIOs and pinctrl (pin function selection) intentionally use orthogonal "name spaces"; it is perfectly permissible to use the same pin from both worlds without generating an error. They later added an option to make the checking strict, but this is not enabled by default.
Perhaps something has changed in this regard, but that would surprise me because Milhouse's LibreElec builds have been on 4.18 for some time and many of those users will be using external soundcards with similar overlays, so should have encountered the same problem.
Posted: Sun Oct 21, 2018 4:19 pm
by DougieLawson
It's also doing lots of bad things with the WiFi
[   44.152008] FS-Cache: Duplicate cookie detected
[   44.152021] FS-Cache: O-cookie c=7ccc6197 [p=af949622 fl=222 nc=0 na=1]
[   44.152024] FS-Cache: O-cookie d=553028c3 n=84fc5ba4
[   44.152028] FS-Cache: O-key=[10] '0400020008010a0101e6'
[   44.152051] FS-Cache: N-cookie c=7e98e9f7 [p=af949622 fl=2 nc=0 na=1]
[   44.152054] FS-Cache: N-cookie d=553028c3 n=8c044246
[   44.152057] FS-Cache: N-key=[10] '0400020008010a0101e6'
[   50.287568] fuse init (API version 7.27)
[   56.355905] IPv6: ADDRCONF(NETDEV_CHANGE): wlxb827eb698d91: link becomes ready
[  134.125662] brcmfmac: brcmf_run_escan: error (-52)
[  134.125682] brcmfmac: brcmf_cfg80211_scan: scan error (-52)
[  135.128161] brcmfmac: brcmf_run_escan: error (-52)
[  135.128176] brcmfmac: brcmf_cfg80211_scan: scan error (-52)
[  136.130315] brcmfmac: brcmf_run_escan: error (-52)
[  136.130326] brcmfmac: brcmf_cfg80211_scan: scan error (-52)
Posted: Mon Oct 22, 2018 11:39 am
by cjan
4.19 is out.
