Page 9 of 12
Re: Moving Linux kernel to 4.19
Posted: Mon May 20, 2019 4:35 pm
by dom
And yes, I can confirm 4.19 is now available in apt repo.
Posted: Mon May 20, 2019 11:59 pm
by Chimneyfactory
And it's this that seems to have made my HDMI sound intermittently choppy / strange sounding. This problem was persistent across reboots.
Reverting to 4.14.98
sudo rpi-update a08ece3d48c3c40bf1b501772af9933249c11c5b
resolved the problem.
If I can provide any further info that might be useful, please let me know.
Posted: Tue May 21, 2019 8:48 am
by girante
dom wrote:
Mon May 20, 2019 4:19 pm
girante wrote:
Mon May 20, 2019 2:47 pm
Since today I am having issues with accessing i2c channel 0, which I fixed by rolling back to kernel 4.14, as suggested by Chimneyfactory (Thanks!)
Can you create an issue here: https://github.com/raspberrypi/linux/issues
and describe the minimum steps you need to do to see the problem with 4.19 vs 4.14.
Done: https://github.com/raspberrypi/linux/issues/2981
Posted: Tue May 21, 2019 11:14 am
by dom
where we can try to work out what caused the behaviour change.
Posted: Tue May 21, 2019 5:42 pm
by Chimneyfactory
Having tinkered a bit more today, I've discovered a problem with reporting it - I can't reproduce the problem outside of this pi and it's installation :(
Existing installation :
4.14.98 : I get 2 brief dropouts within first 2 seconds of MP3 playback in VLC. X-RDP audio works fine
4.19.42 : As above, but continued occasional dropout and clicks can be heard. X-RDP audio very distorted
New installation :
4.14.98 : Sound works fine, no dropouts at all
4.19.42 : Sound works fine, no dropouts at all
(I didn't test X-RDP on the new installation)
So, there's something weird with my installation, which is made worse with the new 4.19.42 kernel / driver package
I'll hold off from reporting it through github unless I can make it reliably reproducable - looks like somethings wrong with my install.
Posted: Tue May 21, 2019 8:03 pm
by Chimneyfactory
I've managed to get it repeatable on a fresh install, so logged here https://github.com/raspberrypi/linux/issues/2983
Summary :
Clean install 4.14.98 works fine
Clean install 4.19.42 works fine
4.14.98 with additional software (listed in issue) - some MP3 dropout at start of play, X-RDP is fine
4.19.42 with same additional software (listed in issue) MP3 dropout worse and clicks audible, X-RDP audio distorted
Posted: Wed May 22, 2019 2:10 pm
by kozman
I was looking at what was going into 4.19.45 the other day and saw a ton of ARM related work. Hopefully the Pi will benefit.
Posted: Thu May 23, 2019 7:47 am
by itsmedoofer
Should we be seeing the 4.19 kernel when we do an apt update ?
Two of my Pis are on 4.19 now, a Zero and Pi1B but the Pi2 is still on 4.14 with no sign of an update.
Have I missed something?
Posted: Thu May 23, 2019 8:58 am
by rpdom
It seems so. I just did an update and reboot on one Pi and it's now running 4.19.42
Is your Pi 2 running Raspbian Stretch?
Posted: Fri May 24, 2019 10:49 am
by itsmedoofer
Yea all on stretch.....
Posted: Tue May 28, 2019 3:37 am
by binaryhermit
I can't help but think the pi2's update slipped through unnoticed and it'll be on 4.19 once rebooted?
Posted: Tue May 28, 2019 6:31 am
by itsmedoofer
Doh !! Just looked at the up time, 30 odd days, rebooted and I'm magically on 4.19 now.
I usually reboot after an update, must have got distracted here though, thanks for the top tip:)
Posted: Tue May 28, 2019 7:04 pm
by dariuszb
with upgrade to 4.19.46 I seem not to be able to disable internal wifi card on RPi 3 B+.
Until now dtoverlay=pi3-disable-wifi in /boot/config.txt did the job. With 46 wifi is on again despite unchanged /boot/config.txt
as I can tell there is no change in Device Tree overlays for wifi (but it was changed for other things)
https://github.com/raspberrypi/firmware ... ays/README
Posted: Tue May 28, 2019 8:59 pm
by DarkPlatinum
Using fake KMS, 192mb split on RPi 3B+ chromium 72. Getting stuttering in 480p video (non fullscreen).
Posted: Tue May 28, 2019 9:45 pm
by kozman
And you're on 4.19.42 or 4.19.46?
Posted: Wed May 29, 2019 11:50 am
by DarkPlatinum
I am on 4.19.42.
Posted: Wed May 29, 2019 12:06 pm
by dom
Are you saying this configuration has worked better with a previous kernel? If so, which one.
Posted: Wed May 29, 2019 6:23 pm
by DarkPlatinum
It had worked better on the 4.14 kernel, (not sure what version but one of the latest ones).
Posted: Thu May 30, 2019 3:41 pm
by dom
Can you identify the exact update which caused this. See:
https://github.com/Hexxeh/rpi-firmware/commits/master
If you click on each commit the end of the url contains a git hash. Run
sudo rpi-update <hash>
to revert back to that version. Report the first version with this problem.
Posted: Thu May 30, 2019 7:46 pm
by DarkPlatinum
What I have found so far with the 4.19.42 kernel is the full-kms driver works fine in 720p fullscreen whereas the fake-kms lags. Could just be a driver issue?
Posted: Thu May 30, 2019 8:08 pm
by kozman
Probably not likely to help much but is it any different under 4.19.46?
Posted: Fri May 31, 2019 10:01 am
by DarkPlatinum
Upgrading to 4.19.46 is going to be a problem. I use this Raspberry Pi for daily use so if I have issues with the kernel I may lose some data. For the time being I only update with apt-get update (rather than rpi-updat/upgrade).
What I can do is provide data to be used as a comparison on your system.
Kernel 4.19.42, Raspberry Pi 3B+, 192mb split, full-kms:
glxgears averages 53 fps
Raspberry Pi desktop opengl test averages 6 fps.
Posted: Fri May 31, 2019 7:17 pm
by kozman
I understand. Do you by chance have a spare micro SD card you could clone your current setup to for testing?
Posted: Sun Jun 02, 2019 12:15 pm
by Twell
Today ( 2 Jun 2019 ) I did the controversial update and for now everything seems to go well.
My system before the update :
df -h
Filesystem      Size  Used Avail Use% Mounted on
/dev/root        58G  1.2G   55G   3% /
devtmpfs        459M     0  459M   0% /dev
tmpfs           464M     0  464M   0% /dev/shm
tmpfs           464M  6.2M  457M   2% /run
tmpfs           5.0M  4.0K  5.0M   1% /run/lock
tmpfs           464M     0  464M   0% /sys/fs/cgroup
/dev/mmcblk0p1   43M   23M   21M  53% /boot
tmpfs            93M     0   93M   0% /run/user/1000
uname -a
Linux raspberrypi 4.19.42-v7+ #1219 SMP Tue May 14 21:20:58 BST 2019 armv7l GNU/Linux
lsb_release -a
No LSB modules are available.
Distributor ID:	Raspbian
Description:	Raspbian GNU/Linux 9.9 (stretch)
Release:	9.9
Codename:	stretch
My system now - after the update - :
df -h
/dev/root        58G  1.3G   55G   3% /
tmpfs           464M   12M  452M   3% /run
uname -a
Linux raspberrypi 4.19.46-v7+ #1230 SMP Tue May 28 16:18:48 BST 2019 armv7l GNU/Linux
In your opinion do I need to check something?
Thank you.
Posted: Mon Jun 03, 2019 10:37 am
by dom
Nope. Minor kernel bumps rarely cause issues so you shouldn't expect a problem, but there are rare exceptions.
The major kernel bumps (e.g. 4.14->4.19) have a higher chance of issues, but they seem to have been resolved now.
