raspz1
Turning on/off USB Power
Mon Jan 22, 2018 7:43 am
Hi All!
I have a quick question.
Using the following code I found in another topic on this forum, I am able to successfully cut power to a USB device on my Raspberry Pi Zero W:
echo 0 > /sys/devices/platform/soc/20980000.usb/buspower
sleep 5
echo 1 > /sys/devices/platform/soc/20980000.usb/buspower
However, no matter how long the sleep time, it still only cuts power for 1 second.
I was under the impression it should stay off until the echo 1 command is sent.
Am I doing something wrong?
Does anyone know how to cut power for 5 seconds?
I have a USB device that freezes, and would like to automate unplugging/replugging to save me the tedious exercise of doing so manually each day
drgeoff
Re: Turning on/off USB Power
Mon Jan 22, 2018 9:40 am
I don't know what you are smoking but you are under a delusion! It is impossible for software to cut power to a USB device on a RPi Zero(W). The power pins on its micro-USB data socket are directly connected to the power pins on the micro-USB power socket, the 5 volt and ground holes of the GPIO header area and the inputs to the DC-DC converters on the board.
raspz1
Mon Jan 22, 2018 9:59 am
Heya drgeoff,
Haha yeah that’s what I read when I first started looking into the issue, but it actually does work.
I was as surprised as everyone else haha
I read an explanation somewhere that said it uses a work around, telling the Pi there was a power surge or something so it cuts power - but don’t quote me on that.
I can post a video of the device turning off when I issue the command if that helps :)
raspz1
Mon Jan 22, 2018 10:07 am
Here ya go.
Excuse the video, I’m currently overseas and friend was holding the dongle for me and filming the results (to see if it would turn off).
It does and can no longer be found by lsusb, and when it reloads has a new IP address and everything:
http://sendvid.com/fukj9xmq
mattmiller
Mon Jan 22, 2018 10:38 am
#TopTip
When repeating a question you've already asked somewhere else - copy and paste your whole post - don't give a cut down version
We are not psychics :)
https://stackoverflow.com/questions/483 ... -4g-dongle
raspz1
Mon Jan 22, 2018 10:44 am
Hi Matt,
Yeah I wasn't sure if I should copy it all or not?
I figured this question was much more specific and as someone else was likely to search this topic at some point too using this title, it might be better in the long run?
Thanks for your input though :)
topguy
Mon Jan 22, 2018 11:42 am
My guess is that the power is not removed but a "reset" (or shutdown) command is sent to the device, and that causes what you see in the video.
raspz1
Mon Jan 22, 2018 2:00 pm
Hey topguy,
Thanks for your message!
Out of curiosity, have you seen this thread?
viewtopic.php?t=93463
Although it’s for another Pi model, there seems to be some conflicting/interesting discussion about what’s happening to cause this functionality.
Also, if it’s sending a reset command, would it reason to assume there’s a shutdown/start command too?
drgeoff
Mon Jan 22, 2018 2:37 pm
A already stated, while the Zero(W) is powered up there is ALWAYS power to the micro-USB data socket.. Therefore any reaction to a software command is a function of the USB device that is plugged in. And not all will behave in the same way.
PlanB
Tue Jan 23, 2018 7:19 am
I've given up on the Pi zero for low power apps because you can only put USB modems to sleep not switch them off. I can get lower current drain with a full sized board pi2 B+ using os.system("echo '1-1' > /sys/bus/usb/drivers/usb/unbind") in Jessie to physically switch the ports off. It's a difficult topic to research online, so much irrelevant guff from earlier hardware & software that is simply no longer applicable.
Return to “Advanced users”
